Question about Dell Latitude D600 Notebook
No power laptop when in use went off, nothing on the screen. pressing the on button and nothing happens. The adapter reads green when plugged into wall but shuts off when attached to computer. no life from the battery.
  • jimmy1111 Feb 15, 2008
    computer is 3 years old and has no warranty
  • 55 Answers
It sounds like there is a short in the power supply. If the laptop is still under warranty, you'd be best off sending it in for repairs.
Posted on Feb 15, 2008
I have a compaq presario cq50-107nr and i plug my charger in the front light is on but when i press the power button to start up the light goes off and nothing happens help? It happen several times and i...
Please 1. unplug the ac adapter, detach the main battery, press the power button for 15 seconds, plug in the ac adapter, and restart your laptop. If the problem persist: 2.unplug the ac adapter, detach the main battery, press the power button for 15 seconds, take out the hard drive, plug in the ac adapter, and restart your laptop. If the problem persist, then it means that the laptop motherboard is dying. Please read your laptop's service manual before you open the laptop's case/body.
Mar 01, 2014 | Computers & Internet
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
My laptop screen went to a solid red ,blue,green and back to red. nothing will work. please help. this occurred while in the midst of using
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Sep 18, 2011 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
I tried to power on my computer and there was nothing. It was plugged in and the battery light was blinking amber when I tried to press the power button. The light on the power cord is green but there is...
It sounds like the Power adapter is:
1. Not plugged into the computer
2. Not functioning
3. Has a broken connector (or the laptop has a broken power connector)
Unplug the adapter, remove the battery, hold the power button on the laptop for 30 seconds. Plug in the power adapter connector to the laptop - if the power indicator illuminates, remove the power cord, insert the battery ant then plug in the power cord. Press the power button (hopefully you're back in business).
If that does not help, p borrow an adapter from a friend and try it with your laptop, if it works, then go buy a new adapter!
Sep 05, 2011 | Acer Aspire 7740G6364 (lxplx02165) PC...
Power cord pluged in, turn on computer entered password, screen went black, power on button blinks green instead of steady on, wont do nothing else, what happened, what do i do now?
Unplug the power cord. Remove the battery. Press and hold the power button for 60 seconds then release. Plug the power cord back in but leave the battery out and try to turn it on now. If it comes on you can put your battery back in. If it still does not come on you may need a new power supply/ adapter.
Apr 06, 2011 | Acer Computers & Internet
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Computer does not turn on when I press the power button
do u have the power adapter plugged in, or are you using battery power? the first thing i would try is disconnecting the battery. just compleatly remove it and set it aside. then try starting it with the adapter plugged in. sometimes the batteries go bad and are corrupt. i had this happen to a compaq laptop a few years back. after i got rid of the battery it worked fine. if it works u can always buy a new battery.
Feb 26, 2009 | Averatec 2371 AMD Turion Notebook
I have satellite 135- s2276 purchased about 12 months ago. Nothing happens once you press the ON button . The only thing that functions is the green button indicator that shows that it is plugged...
Unplug the ac adapter and then take the battery out press the power button on the laptop for 30 seconds without connecting the battery and the adapter this will release the static power of the system after that you can put the battery in and then the ac adapter. Turn on the system it will work.
Apr 09, 2008 | Computers & Internet
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
Aug 14, 2007 | Acer Aspire 3680 Laptop
Dell Latitude D600 Notebook Logo
41 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
