The memory card when put in flashes memory card error,it is in the correct slot the correct way up
If this machine is a wascomat..that means the memory card has not been formatted.
Posted on Feb 16, 2008
Card error light flashing green
When the camera accesses the memory(card) a green LED will burn or flash. When it can't do what it wants, it will warn you.
A memory error, can be caused by lots of things. Like card full, card physically damaged, file system damaged. Too many folders, too many pictures. Wrong card (SD, SDHC or SDXC) cannot be used in every camera.
Check if you did put in the card correct (not the wrong way around) Check if all contacts on the memory card are clean, shiny and straight. Check if you did not switch the lock switch to the wrong position. Check if there are still pictures on the card, in an external memory card reader. put all the pictures you can find on the computer and than try to format the card. (in the computer, FAT 32) but after you put it in the camera. do a format in the camera too.
Mar 05, 2014 | Samsung L200 Digital Camera
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
Connect to a system error occured formetnow please give me solution
if u have a card reader put the memory card in the card reader slot connect it to the computer and a removable drive will appear right click it and select the option format and format it.
May 18, 2011 | SanDisk 2GB microSD Memory Card
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
Printer error 70
Brother DCP-165C inkjet All-in-One Printer Error Messages
Once you are familiar with the types of errors that can occur while you are using PhotoCapture Center, you can easily identify and troubleshoot any
Hub is Unusable.
This message will appear if a Hub or USB Flash memory drive with a Hub has been put into the USB direct interface.
Media Error
This message will appear if you put in a memory card that is either bad or not
formatted, or when there is a problem with the media drive. To clear this error, take out the memory card.
No File
This message will appear if you try to access a memory card or USB Flash memory drive in the drive (slot) that does not contain a .JPG file.
Out of Memory
This message will appear if you are working with images that are too large for the machine's memory.
This message will also appear when a memory card or USB Flash memory drive you are using does not have enough available space to scan the documents.
Media is Full.
This message will appear if you are trying to save more than 999 files in a memory card or USB Flash memory drive.
Unusable Device
This message will appear if a USB device or USB Flash memory drive that is not supported has been connected to the USB direct interface (For more information, visit us at This
message can also appear if you connect a broken device to the USB direct interface
Nov 03, 2010 | Brother DCP 165C Compact Color Inkjet...
Sd slot used to read cards, now "memory card error"
i am trying to copy my photos from my 4 GB SD memory card on to my computer through my printer HP PSC 2355 all in one printer. But as soon as i put the card into the slot it turns green and the a couple of minutes later turn Red and flashes and i cannot read it on my computer
Dec 04, 2009 | HP Office Equipment & Supplies
My Memory Stick does not register to my Macbook Pro. I have put it in the the SD slot countless times every way.
memory stick pro duo slot is different from SD slot. get a inexpensive card reader which supports memory pro duo cards.
Aug 07, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
use it. the card likely has some data or (corrupt data) on it that the phone dosnt like.
the card might also be physically bad or going bad or damaged. FLASH cards die over time just from using them.
Jul 03, 2009 | SanDisk 2GB microSD Memory Card
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Not recognizing memory card in slot
are you sure you are sticking it in the correct slot for your memory card and you are not sticking it in backwards/ upside down
also this memory card works in your cammera still correct?
Mar 31, 2009 | HP DeskJet 5650 InkJet Printer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
