Question about Toshiba Satellite M45-S265 Notebook
Power Up Problem
I have a Satellite M45. I have the unit plugged into the power supply and the battery lite shows it is charged. However, when I try to turn the unit on, all it does is the power button turns blue for about 5 seconds and the cd/dvd drive starts to spin and then it shuts down.
  • nyjrock Mar 06, 2008
    I have a toshiba m45-s265 it powers up and runs windows. Then all suddenly shuts off: the ac power light goes out and so does battery light. I tried changing battery same problem. I tried with no battery same problem.
    Master:
  • 474 Answers
If its unplugged and its doing this with a charged battery, then the battery may be bad and its max charge is so small that it wont start but says its full.
Try removing the battery and plugging it in and starting it, if it works, Bad Battery.
Itry removing the CD drive, some older Dells would do the same thing when the drive or bagttery would go bad. If so, then Bad Drive or battery.
Try taking out the Hard drive and then starting it with no Hard drive and see if you get a bios screen, if so, go into the bios and reset everything to defaults and try starting it again with the HDD put back in.
If its really old, past 3 years, the bios battery may have god out and needs to be replaced, some laptops have a watch battery soldered in or a rechargabl battery that connectd to the board, if so, its up to your ingenuity to replace it with a new one however you can. although i would try this if your not mechanically inclined, taking apart, most laptops is difficult unless its your job and you know your stuff.
Hope this helps a little.
Posted on Feb 15, 2008
Computer is now completely dead. WHen power supply pluged it, blue LEDs indicate it's getting power and battery being charged. But on/off switch has no effect, button puch won't open CD drawer, etc. --...
"Battery being charged" indicates that this is a laptop. Auto shutting down indicates that you are having issues with the power supply/brick. One thing to try is another known good power brick. Otherwise it is likely your power inverter inside the laptop.
Jan 05, 2018 | Toshiba Satellite M45-S359 Notebook
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Thanks
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
Satelite Toshiba M45-S165. WOrked fine, now won't boot
To sure the battery problem or bad. try to change another battery for testing only befor you replace at all.. I thing this over charging of the battery. then the battery became damage or bad.. to sure change other battery..
Thanks
May 11, 2009 | Toshiba Satellite M45-S165 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Power problem - led shows the ac plug is in - battery does not charge - can not run laptop on ac adapter - what is causing this problem
The connection to the power supply inside the Pc is or has gone,
because your using the connection 1000 times a year, it faulters, and fails.
$150/$200 to get repaired.
Strip out the laptop solder connection back up,
rebuild, very common problem.
Regards
Richard.
Apr 18, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite no power
replace only the power jack and clean the power supply board with some alcohol...you can find the jack in some electronic shop..
Jan 04, 2009 | Toshiba Satellite M45-S169 Notebook
Toshiba satellite m45-s169
with the operating disk you can repair a windows installation( system files ) and not lose any saved data(files)
Oct 08, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba M45 S331 power issue
Try this, remove the power supply and battery. Let it sit for about 15 minutes then re install the battery and power supply.
Oct 06, 2008 | Toshiba Satellite M45-S331 Notebook
Battery problem
u try new power plug unit supply next i would try that or does battery show full charged but wont start then mobo has bad power chips on it they can redo them or u can buy new mobo to install in also cheak screen cond cables ect
Feb 04, 2008 | Toshiba Satellite P105-S6024 Notebook
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
