Question about Samsung SmartEther Networking Hub
SmartEther SH2224S Password
I'm trying to get one of these old Smart Hubs set up but I do not know what the default login is. Does anyone remember the default username (admin?) and password for these things?
  • 1 more comment
  • TomOwens Feb 15, 2008
    OK, I'll answer my own question:
    Factory default
    username : samsung
    password : samsung
    They are case-sensitive.
  • techkid99201
    techkid99201 Mar 09, 2012
    how did you get to the login screen like by an ip or software how?
  • techkid99201
Username : samsung
password : samsung
Posted on Feb 16, 2008
How do I fully reset my AP7161
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usual be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware sestets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
May 12, 2014 | Motorola AP 7161 Access Point
Hi all i hv configured dlink switch DES 3350sr with user name and password. i saved. but now problem is that when i reboot this i can not login with that user name and password. so after all problem is...
evidently your sign in name and password were not saved. If you remember the old password and name try that. IF not, thenn find the reset switch, press it and start fresh with factory defaults
Mar 16, 2011 | D-Link (DES-3350SR) (851210) Networking...
Reset password
On the back of your router, there should be a reset button. Press this button and set up the router again by connecting the router to your computer using an ethernet cable.
Mar 08, 2011 | D-Link DIR-615 Wireless Router
How to connect
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
user ADMIN for login and leave password blank then you can connect using the wizards.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Feb 25, 2011 | D-Link DIR-615 Wireless Router
I have a Linksys WRT160N Wireless router and I had set a username and password, since I had to reset it the username and password I set will not work. I also tried using the username and password as...
Try leaving the username blank and just typing admin in the password. If you remember your old username and password try those too, You may not have saved changes.
Jan 17, 2011 | Linksys WRT160N Wireless Router
I have a netgear FS726TP and need to reset the forgotten password
You will need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Aug 06, 2010 | NetGear ProSafe FS726TP Smart Switch...
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
Password recovery
Ouch its easy to do I used to write these down and put the paper somwhere safe where I would remember it (NOT)
All is not lost you can download the manual from here if you know your version number.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041005164950#
or you can try the default from the web interface http://192.168.1.1
PW 1234
or reset by loading up your saved configuration or from the console commands
Full instructions are in section 4.5 of the manual and are too long to just post here
Aug 11, 2009 | Zyxel GS-3012F (GS3012F)
I don't remember how to login to my linksys configuration
Hello
I am not sure the IP you put in the message is the right one. Assuming that you are still using the default settings, the IP is 192.168.1.1
open internet explorer or your default browser and type: http://192.168.1.1
and you shoulfd see the login page and if you forget the default login try
user: admin
password: {blank} nothing
or
user: {blank}
password: admin
Apr 13, 2009 | Linksys Wireless-G WRT54G Router
Samsung SmartEther SS6212
orange white orange green white blue blue white green brown white brown on the plain side you have to look
Oct 03, 2007 | Samsung SmartEther Networking Switch
Samsung SmartEther Networking Hub Logo
251 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
