Old Sony KPR-53EX35
It was suggested by a friend who had a similar incident that my high voltage transformer was probably the issue with this old set because it had no picture just a snowy one. Have any tech here had any experiences with these sets? If it might be the high voltage transformer how does one find a replacement part? I know the set is old, but if I can repair it for a little money I figured, why not?
Thanks
  • 4day Feb 15, 2008
    Jaime867,
    Your were correct ! I connected a DVD to Video 1 and it works fine. I guess that I would connect my Satalite reciever to a VCR Source and then to my Video 1 input on the TV it should work the same....correct?
    Thanks again !!
  • 2,336 Answers
If you have snowy picture on this TV set, the problem is not your high voltage transformer,
The defective part is more likely the tuner or the IF section of the TV.
I would suggest to use a video source from a DVD player ot VCR and connect the audio & video output to the audio & video input on the TV. Do not forget to select video 1 or 2 on the TV.
Hope this helps.
Posted on Feb 15, 2008
  • Jaime Hernandez Feb 15, 2008
    If you have any more video inputs on that TV, you can connect the satellite receiver to video 1, the DVD to video 2 and the VCR to video 3.
    Thank you for the rating.
Not heating
If it sounds normal, but does not heat, you probably have a defective component in the high voltage circuit. If it's older than 7 years, or has been used to heat a lot of low water content food (popcorn or similar), then magnetron failure is a strong possibility. If it's not humming nearly as loud as before, though, you could have a bad relay, and the high voltage transformer may not be receiving power to its primary winding.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 14, 2016 | Microwave Ovens
Toshiba cz 36t31 suddenly has no sound and shows no pic only the red on light comes on..how do i fix this and is it worth fixin???
If the red light on little chance of a fuse, set is large and old enough unless you have some experience or know someone who does you may not be able to fix it.
Issues range from broken connections at for example the high voltage transformer to elsewhere in set or almost any part in power supply for this issue.
Typical high voltage transformer--look do not touch.
Dec 11, 2012 | Toshiba CZ36T31 36" TV
D52w20
This set is known for some common issues--one is a built in feature where it will try to come on three times and if fails goes into shutdown.
The most common issue is bad solder connections where the high voltage transformer is soldered into the board and right around it.
It has some convergence issues but set will still play.
On the board where the transformer is located it can fail and some other parts (output transistor shorts).
It is not repair friendly as all parts are specialized.
If going to look--look for the bad connections first.
photo here of typical high voltage transformer:
Jun 12, 2012 | Pioneer Televison & Video
Burning smell, then quit. 4 yrs old.
That is not a good sign, the problem is in the high voltage, especially if it was a funny smell it would indicate the high voltage transformer "flyback transformer" is toast along with other parts. The set is 4 years old, and new tv's are designed to break down anywhere from 3 to 5 years, probably more cost effective to buy new.
Jan 13, 2011 | Philips Magnavox 27MS343S 27" TV
My Flair smells like it is burning and the plates are making a loud sparking sound
What's burning is probably your high voltage transformer. When your glass plates get a crack in them, they will spark. You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 01, 2010 | Ecoquest Flair Air Purifier
Sony kv 36xbr400 - Won't stay on
Problem is in the secondary power supply which provides power to high-voltage and scanning sections of main board. This is called BOARD D, and has the high-voltage section, flyback transformer, and control IC on it.
Can't be fixed by user, needs service tech and new part, around $300
Oct 12, 2008 | Sony KV-36XBR400 36" TV
Any Whirlpool Microwave Techs out there...Please help a fellow tech
hi mike,
I’m sorry to tell you this but; I wouldn't recommend using a different transformer, even if it's the same size, it could cause serious damage. The HV transformer should only be replaced with the exact replacement part.
Mar 21, 2008 | Microwave Ovens
KPR-53ex35
Your black and white board may need to be replaced.
Dec 11, 2007 | Sony KP-53V35 53" Rear Projection...
No picture
This looks like a problem with the Hv Voltage section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, or have this done by a qualified TV technician.
Or check the voltage test points on the HV / Horizontal board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I would suggest that if you do not have a background in electronics that you have a qualified electronics technician who knows TV take a look at your set and perform these test.
I hope this helps,
Thank you,
Shuttle83
Sep 17, 2007 | Sony KP-46WT500 46" Rear Projection...
Pincushion problem
My thoughts would be, was it a Sony OEM transformer or a generic type? If the latter, that is probably a likely suspect. Another thing would be misplaced wires or switches that could have been accidently moved while replacing the transformer. I have had some of these sets that had no high voltage, and all it turned out to be was a broken solder connection on one of the pins going to the flyback transformer. Usually, if the flyback is bad, the Horizontal output transistor would be also defective. It's also possible that in the process of removing the old flyback (fun job wasn't it?) you may have cracked one or more of the circuit traces in that area of the PC board.
Jan 01, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
