Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Drops connection after connect, sends 2-3 pages
Fax machine moved from NY to CA, went from standard old line to a VOIP line, dials out fine (dial 9 first), connects as it should w/o problems, starts sending fax and dies after 2-3 pages.
It receives fine so far but I've only received 2-3 page faxes, nothing larger.
I'm guessing it has to do with the baud rate (V34/33000). I have no manual and don't know how to change the settings to SLOW down the connect speed.
Can anyone offer some help in how to navigate the menu/function screens?
Thanks!
    Scholar:
  • 159 Answers
The fall-back required for transmission over VOIP is not available on this machine. It is a service mode function and can only be set by a technician. However, VOIP is so iffy for transmission that you may require fall-back to 4800 or even 2400. I have found that forcing fall-back more than 2 steps doesn't work.Also the Line equalisation can't be set as there is only 3 settings, 1.8;3.6; and 7.2 Km. Who knows how far to set VOIP, could be 3000KM. I had more success using a very old fax machine sending at 2400BPS that I could set the dip switches. Takes all sorts of changes to have success and then next time you try, it's changed again.
Posted on Feb 16, 2008
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
Apr 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
http://www.allnet-italia.it/img/speciali/pdf/777702433.pdf
if you need more call me at 804-372-RROD
May 03, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Can't fax
Can you send faxes to a local number? If you can the problem is likely to be that there is no long distance carrier set up for your new VOIP service. You could also try using a regular telephone connected to the same jack as the fax uses to try dialing a long distance number, this may give you a hint as to what's wrong. You should also contact Comcast tech support about this problem, the VOIP box may not be properly configured for long distance service.
Carl
Dec 04, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Cannot send or receive faxes
How to dial *xx codes when faxing When sending a fax, it may be necessary to enter in a *xx code as the first part of the number. Follow the steps below to dial *99 when using a VoIP service. NOTE: Since the *xx code is an instruction to the phone system, this must be dialed live.
  1. To pick up the line on the HP All-in-One, press Start Black Fax or Start Color Fax without entering a phone number first.
  2. When you hear the dial tone, enter in the *99 code.
  3. Wait a few seconds and then enter in the rest of the number.
  4. The HP All-in-One will complete the fax as normal.
What can be done to help the fax transmission? The communication speed is a major factor in fax transmission over VoIP. Currently there are three speed standards.
  • Fast - v.34 which communicates at 33.6 Kbps.
  • Medium - v.17 which communicates at 14.4 Kbps
  • Slow - v.29 which communicates at 9.6 Kbps
Changing the Fax Speed Adjustment setting to Medium may improve your ability to send a fax over a VoIP network. On most HP fax products the connection speed can be set to a lower speed. Those that do not have a Fax Speed setting generally communicate at medium speed or lower as this was the past standard. Consult your user's manual for information specific to your model. Changing the Fax Speed Adjustment to a lower speed Follow the steps below.
  1. Press Setup .
  2. Select Advanced Fax Setup .
  3. Press OK .
  4. Select Fax Speed .
  5. Press OK .
  6. Select Medium .
  7. Press OK .
  8. Try the fax again. If you continue to have problems faxing, contact your VoIP provider as they may have options to improve the ability to send and receive faxes over VoIP telephone service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon MP830 - Outgoing fax dialing not connecting
Are you plugged into the LINE port of the fax machine?
Oct 21, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Can't receive and send fax
check to see if your phone line is plugged into correct slot marked with an " L " or line on your fax. and that you are getting a dial note from your fax by selecting the speaker button or by connecting a phone into the other slot on your fax marked by a phone and listen for a dial tone.
Thank You,
Mikey
Apr 03, 2008 | Canon FAXPHONE L80 Laser
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
225 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
