Question about ASUS A7V333-X (A7V333-X/L) Motherboard
Power Switch for this PC?
I've been looking all over the internet for a power switch for this mother board. I have many spare PC's lying in my attic and not one power switch off of any of them will fit this. Anyone know a place to where I can find a power switch?
I would like to get this PC running ASAP. Thx in advance!
  • D347H Mar 08, 2008
    ty ever so much, yes its the push power button that I need for an ATX power supply box. I will maybe try splicing considering most of my computers are ripped apart anyways and some dont even have cases and I still run them. I will check out some stores and see what I can find, $10.00 is def. cheaper than a new case lol. As for my motherboard having a manual, it doesn't. a friend of mine mailed me it for free so I am working on this thing in the dark. I'll look for the 2 pins on the board and see if I can find it. Never used an AMD before, I have all intel boards. *thumbs up* for your response :)
  • 2,351 Answers
I've read your question & am still confused about which switch you need. I'm guessing that it's the power switch on your case that is broke? If so you can go to just about any auto parts store & buy a push-button two wire off/on switch. Even in a Low's store. It may or may not fit just perfactly on your case but it's better then turning the power off with a pen directly off the motherboard. Been down the road your on. It's either this or buy another case. You will not find your case a new switch. You can use your case's wiring connector to plug into the board listed on pg. 1-18 in your manual. It's two pins. You can splice the two pin connector from your case to a new switch's wires. As far as connectors go. You can buy a small pack of single connectors for a computer from radio shack to connect to the boards (power) ATX power switch. All the parts shouldn't cost you more than $10.00. Cheeper than a new case!
Posted on Feb 16, 2008
My Dell Optiplex Gx 620 isnt turning on..... No lights no sounds is it the motherboard
Bad power supply first, or just the switch. The mother board will keep it from posting, but lights should come on. a bad power supply or switch it will be dead like fred.
If your handy there are many tutorials on diagnosing a power supply on the internet. Usually when it is the mother board there will be a few beeps or flashing lights then a shut down, or frozen pc on boot then death.
But all these symptoms can come from a dead or dying power supply. Do this at own risk..
Jul 07, 2012 | Computers & Internet
Hp D 530 - DK907T 902-FAN COMMAND 2 PIN CONNECTOR FROM POWER SUPPLY NOT CONNECTED NB i've changed the chassis it was SFF ans i 've changed in Tower with a standard power supply
Maybe you put the wrong jumper of the power jumper for the front panel.
You can see the switch to turn on the PC right, then make sure that switch correctly installed on the right jumper on the board. Follow the cable to attach to the mother board.
Aug 22, 2011 | HP Compaq Business Desktop d330 Slim Tower
P4b533 i dont remember how i make a reset and power cinch on computer to mother board with cable
if your board screwed on its case already,
there is a 9 pin color black at lower right side of your board if your infront of it, in usual position. firs t(2) two in upper right is for the power switch, and the two pin behind it is for the reset switch. the two pin beside of power switch at left is for power LED/Light, behind that is for HDD LED.
spare the last pin left at lower right.
Mar 12, 2011 | ASUS P4B533-E (P4B533-E/L/1394)...
Server is not powering on
Switch PSU between bays Use spare PSU
If server is still not working PSU backplane needs to be replaced. IS spare PSU sovles the issue, then it was a faulty PSU
Feb 26, 2011 | HP Compaq ProLiant ML350 G5 Server
Gateway T2838 with Intel 4000812 motherboard wouldn't power up. Replaced mother board and power supply. New components also won't power up. Both boards have green ready light lit on the board and both...
Check ALL your USB ports.. If any of the USB ports have shorted contacts or if the 5v rails are shorted to ground, the power supply WILL NOT switch on.. Also, if any of the items connected to the board have a supply rail grounded, again the board will not allow boot up. Unplug everything from the board and the drive power connectors too, except the power connector to the board and the front panel switches and try to switch on, if it still will not boot, check and recheck the USB ports and all power connectors, if it does, switch off and plug another item in, then switch on again. When you get to the item which prevents the board from switching on, thats where your problem lies. Dont forget, plug things back in one at a time, including the power plugs to the drives and try and power up between each item, and dont forget to power down after each item has been checked..
Mar 14, 2010 | Intel D845GVSR Motherboard
What pin # is this power switch,power led,power reset hd led,on intellistation m pro 6218, 3.2ghz
look for mother board morking,look for the pin that indecates (PS) is for the power switch (PL) power lead,(PR)(P res).and HD led
Dec 05, 2009 | eMachines T6420 PC Desktop
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
No power no light
Could be either one, or it could be the toggle switch.
Start with the easiest first to check. Unplug the power toggle switch from the mainboard and take a screwdriver or something and short out those two pins to see if it starts the pc. if it does, then your pc case switch is just bad.
If that's not the problem, check the power supply next.
Jumper the ATX 20 pin power cable's green wire to any black, just to make sure the power supply is working. The fans in the power supply will turn on along with anything else hooked up.
To jumper the power supply use a section of wire or a bread twisty (with the insulation removed from the ends) and just connect the green wire to any black wire on the 20 / 24 pin power connector. Make sure that the power switch on the back of the power supply is switched on.
If neither of those seem to be the problem, then most likely it is the motherboard or the processor.
Dec 21, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
MSI KT3 Ultra2-R Motherboard
Sep 26, 2007 | MSI KT3 Ultra2-R Motherboard
ASUS A7V333-X (A7V333-X/L) Motherboard Logo
318 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
