Question about Sylvania 2870LV VHS VCR
Tape ejection malfunction
Everything works just fine, but when pushing the "eject" to release a vhs tape, the tape gets hung up inside the unit. I have 3 different vcr with the same malfunction, so it appears this is a common problem. Any suggestions or possible solutions? Thanks.
  • 979 Answers
The problem may very well be a slipping spool idler that does not tension the tape properly when trying to eject. Try cleaning the rubber friction surfaces or replacing the part....accordianman
Posted on Feb 15, 2008
Have unit hooked up, but cannot get the vhs casset tape e to remain in player, keeps ejecting.
Typically a VHS tape has a button on the underside that unlocks when pressed inside the VHS player. The wheels unlock and move the tape in the VHS. If this doesn’t happen, the tape will eject.
Oct 26, 2017 | Televison & Video
How do I release a tap stuck part way in the U760??
i had this model once upon a time. the only way i can think of is to try a mini screwdriver to push in the tab on the vhs tape. maybe then it will move. i had to have mine repaired when my aunt did it to mine, 20 yrs ago.
Sep 22, 2014 | Mitsubishi HS-U760 S-VHS VCR
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Panasonic Palmcorder PV-43D cannot get door open
Hi there.
Sometimes a gentle slap with the palm of your hand with the door facing towards the ground does the trick, make sure you power it off then on press eject while you gently slap it.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
Vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Jul 12, 2008 | Samsung DVD-V8600 DVD Player/VCR
STUCK TAPE
check the tip in my profile
Oct 20, 2007 | Philips VRA999PH VHS VCR
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
Tape door won't open on eject?
Many times I've heard my tape will not eject,most of the time unpluging the unit from the wall for about 10 minutes and then plug it back in,this resets the microprocessor and it goes bak to normal and the tape ejects.I hope it works. Please rate this solution if it does.
Oct 17, 2006 | JVC BR-S822DXU VHS/S-VHS playback VCR
Sylvania 2870LV VHS VCR Logo
193 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
