Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WS 55809
My WS 55809 won't come on...the LED lights up hear clicking like it is going to come but does not. When unplugged and plugged back in the LED flashes 3 times.
Is this a possible fuse problem or power transformer.
Thanks
  • 4 more comments
  • artistb Feb 21, 2008
    Read something about possible (flyback transformer) problem...for a fix??
  • artistb Feb 24, 2008
    Well back again error code 22
    Solution ????
  • Anonymous Mar 01, 2008
    when i turn the set on green power light comes on for 2 seconds then i hear click and goes off no picture what do i do?
  • artistb Mar 13, 2008
    problem solved.... changed out pico fuses 5A and two IC's
  • Julio Derrick
    Julio Derrick Jun 01, 2013
    convergen ic
  • Anonymous Mar 21, 2014
    all inputs have a flickery jumpy screen and the menu screen is clear and normal.
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 21, 2008
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
The power went off and when it came back on the tv wouldnt come on but the timer light is lit
First thing is to unplug the TV for several minutes, replug, Power LED shouls flash for around 90 seconds then go off. Try to power up then.
If the power LED does not stop flashing , or the TV will not turn on still, it will need a repairman.
Oct 22, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi 55859 Blinking Green Light
Video instructions for repairing Mitsubishi WS-55859 HDTV:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Dec 27, 2008 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitsubishi 48" integrated 1080. The Timer green light keeps blinking. I have no picture. Can this be the fuse? My coworkers say this might be the problem. Can I replace it myself? If so, where is it located?
meeh.shell@yahoo.com
Oct 13, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809
Sounds like moisture got into control surface.. Try hairdryer around buttons to dry it out..
Jun 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mits 55809 LED wont flash 3 green after plug in AC
A code 22 means your set is going into protective shutdown due to a short circuit. This could be horizontal output or regulator transistors being shorted. However you will probably need a service manual to pinpoint the problem precisely. You can get a detailed service manual at the following link along with free support to help you diagnose your set's problem. They will also email the manual to you so you have access to it right away. here is the link.
http://servicemanuals.vstore.ca/
Feb 03, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
344 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
