Question about HP LaserJet 4000 Printer
Unwanted Horizontal lines across the printed page
Every time I print a page, I get 3 horizonbtal lines across the page dividing the page into 3 roughly equal sections. I have tried the cleaning page a couple of times but nothing removes them. Chatsworth9
  • 4 more comments
  • Cheryl Way Feb 15, 2008
    But is there any solution I can try to identify which one of those things is causing it and can the average person fix any of the 3? For example, should I try replacing the toner cartridge? But if that doesn't solve the problem, did I just waste the old cartridge or can I reinstall it? I don't even know where the transfer roller is or whether it can be cleaned? Chatsworth9
  • Cheryl Way Feb 17, 2008
    Sorry, I did not click on the links before rating, and this was quite a lot of pertinent information. I would change my rating to Fixya for this guest's solution. Chatsworht9
  • Anonymous Mar 12, 2014
    Officejet Pro 8100 printing unwanted horizontal lines in photo
  • Anonymous Mar 15, 2014
    horizontal line prints on some pages but not all when using c5180 all-in-one
  • Anonymous Mar 17, 2014
    when printing black lines appear across page on all pages
  • Anonymous Mar 21, 2014
    WeP P7-1000 missing some characters and unwanted horizontal lines on print appearing.
  • 32 Answers
Problem is either Laser, Toner cartridge or transfer roller.
Posted on Feb 15, 2008
  • 34 Answers
This is definetelyh a toner cartridge problem. Replace the cartridge and the problem will stop. I doubt this is a fuser problem.
Posted on Mar 12, 2009
Solve horizontal line in cartage 12A
Horisontal line: I assume you mean a line across the paper movement direction. Please, inspect if the line is repeating on exact distance from one to the other. Measure the distance, divide by Pi (3.14) and you'll get the diameter of the faulty roller. Also, please, make a half print test page (open the cover in the middle of the printing process). Inspect if the line is appearing before the fusing unit or after it.
Try printing with different cartridge, just to be sure the cartrige is causing the problem.
Primary charge roller and its bearrings can be dirty and not charging enough the drum, causing black lines
Weared stripe on the OPC drum caused by friction with jammed paper improperly pulled out can also be the root of the problem. Faulty laser-scanner unit can also write black lines randomly. Weared teflon sleeve on the fusing unit can accumulate toner and print repetitive defects.
Oct 09, 2014 | HP LaserJet 1020 Printer
Unwanted colour lines on prints
It may be time for a new printer. Colored lines are often an indicator that the printhead is worn out. Dark smudges on the back of the print are likely just a need for cleaning the inside.
Sep 02, 2014 | DSC GESTETNER - DSc38u Color Printer
Getting horizontal red streaks across printed page
The drum roller is damaged. You must be careful and spin the cylinder. do not touch the roller. You probably have a line in the roller that causes this issue. Each time i have seen this problem, this was the cause.
Feb 12, 2010 | Brother MFC-9840CDW Laser Printer
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printing with a black horizontal line across bottom of the page
Wipe the cartridge.Use cotton but dont put water on it only cotton.if you have deiones water its good to use.
May 20, 2009 | HP LaserJet 5550DN Printer
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
HP LaserJet 4000 Printer Logo
1,950 people viewed this question
Seeker5211
Seeker5211
