Question about GE JVM1490 Convection/Microwave Oven
Convection oven problem
Microwave works convection oven doesnt heat food
  • 1 more comment
  • arthurop1 Sep 10, 2008
    convection oven does not heat obove 100 degree at any setting
  • Anonymous Mar 22, 2014
    oven does not heat before start convection
  • Anonymous Mar 28, 2014
    No other problem
Sometimes the high voltage capacitor may be at fault
Posted on May 12, 2008
I have a Frigidaire microwave oven.... as it was heating food it just died, minutes later the power was back on by itself. I reset the clock and date,all seemed fine till I tried heating-up food.
It does not heat-up. The microwave is 5 yrs. old but in great condition. Is it fixable? Could I do it myself?
Mod # PLMV168CC1
Posted on Apr 11, 2008
  • 2,334 Answers
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Posted on Feb 15, 2008
Tip
Difference between a convection oven and a conventional oven
<span>A convection oven is equipped with a fan to speed the circulation of heat around the food, thus cooking it faster and more evenly than conventional ovens. <br /><br />Conventional ovens rely on radiant heat that rises from the bottom up to the top of the oven. Convection ovens cook foods approximately 25% faster than conventional ovens, and the oven temperature can be reduced by 25&deg;F for most foods. <br /><br />No special cookware is required. Just like conventional ovens, convection ovens can be gas- or electrically-heated. As with any major appliance, it is always best to carefully read the manufacturer's guidelines and instructions for operating the oven.</span>
on Apr 04, 2011 | Microwave Ovens
How do I get the heat to work?
Hi Marc, there is no 'heat' per say with microwave ovens as one would find in a convection oven. Microwave ovens operate by generating electromagnetic fields (within the microwave band) that causes water molecules in the food item to vibrate/rotate creating friction/heat - within the food item as opposed to the surrounding space (this would be convection)
Oct 26, 2014 | Oster Microwave Ovens
The food is not heating
The wave generator (Magnetron) or one of its components is defective.
Nov 25, 2013 | Miele M638EC 1500 Watts Convection /...
I have a sharp over the range convection microwave modelr-1874F The convection works but the microwave sounds like it working, the turntable turns but it does not heat the food we tried unplugging it for...
Every time the microwave part of an oven do not heat it normaly means a faulty MAGNETRON (the device that produces microwves) unfortunately if it's the magnetron they are allmost as expensive as the oven it self, you could allways check for a burned fuse, (allways be prudent opening an applyance)
Jan 04, 2011 | Sharp R-1874 Convection/Microwave Oven
I have a KHMC106W Micro-Convect Hood - all of sudden when we used the microwave it didn't sound right and the food never heated up. I unplugged and waited about 2 min and replugged back in and it still...
the Magnetron has gone (yes it's really called that) that's the part of the microwave that emits radio waves and cooks your food... 30 years ago when this tech (Microwave cooking) was new and expensive it was cheaper to replace that part than buy new... now it's the other way around... at least you still have a working electric convection oven.
it's very rare that a Magnetron go bad, so look for an old one of the same model and use that one for parts if it's that loved.
Nov 18, 2017 | KitchenAid Microwave Ovens
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Sharp R-1870 Convection works, microwave doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytwyys
Oct 07, 2009 | Sharp R-1870 Convection/Microwave Oven
GE JVM1490 Convection/Microwave Oven Logo
506 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
