Question about Citizen 1.44MB 3.5-Inch Floppy Disk Drive (Beige) (LR1043) Floppy Drive
The Z1D CITIZEN floppy drive on this computer cannot read disks. When you put a disk into the drive, it constantly returns a dialog message in windows asking to format the drive - and cannot read any of the data on the diskette.
    Scholar:
  • 148 Answers
Some floppy can read and some floppy cant read
it means that ur floppy drive reads the information which they originally save it from citizen floppy drives. Floppy drives like citizen if u use in any place u can use the citizen floppy drive any where
Posted on Feb 25, 2008
Windows XP download
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
Step 2: Run the Setup disk program to create the Setup disks
When you download the Setup disks, the download contains only one large program file. When you run the downloaded file, it extracts the files. You receive the following message:
This program creates the Setup boot disks for Windows XP. To create these disks, you need to provide 6 blank, formatted, high-density disks.
Please specify the floppy drive to copy the images to:
Type the drive letter for the floppy disk drive (this is typically drive A). After you type the floppy disk drive letter, you receive the following message:
Insert one of these disks into drive drive letter:. This disk will become the Windows XP Setup Boot Disk.
Press any key when you are ready.
When you press a key, the downloaded file starts to extract and copy the files. Continue to insert the blank disks as you are prompted to do this until all six disks are created. If the process is interrupted, you must run the downloaded program file again to create all six disks.
Make sure that you label each disk appropriately with the number that is specified by the program. You must use the disks in the correct order during the Setup process.
Step 3: Start your computer by using the first Setup disk to begin a new Windows XP installation
After you create all six disks, insert the first disk in the floppy disk drive, and then restart the computer. The computer must be configured to start from the floppy disk drive. You may have to modify the BIOS settings on your computer to do this.
The Setup process starts. Insert the other floppy disks when you are prompted. You must use the Windows XP CD-ROM to finish the Setup process.
hope it helps
May 13, 2012 | Microsoft Windows XP Professional With...
Citizen x1de-usb
If you have the disk... The drivers will still not install correctly using the usual method. Do this: Go to the system applet and find the yellow flag indicating the device is not installed correctly. Click on it and go to the box that says "Update the drivers". Put the disk in your CD/DVD drive and "kill" the inquiry box that comes up. Now tell device manager to find the drivers on your computer and point it to the CD drive. Click Install and they will install fine. You wont even have to re-boot probably.
Dec 12, 2011 | Iomega BXXU0130 144MB USB Floppy Disk...
I am now unable to access a floppy disk that I had been able to access for years. I now get an error message that tells me the disk has no ID address mark. How do I fix this?
Try changing the stting switch on the disk. I think it is for formatting or something like that. Try moving it to the opposite direction and then put it in your computer again ;) Good Luck
Nov 12, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Designer I - failing floppy drive
You can get the floppy drive replaced. I did tons of them! I don't think it is you. Sometimes you can "wiggle" the floppy a bit with the little flap door open and get it to read. Not a huge deal to replace.
Aug 03, 2009 | Husqvarna Designer I
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Troubleshooting Floppy Disk Drive Problems in Windowxp
try using the floppy on another computer, if you have the same problem then the floppy is bad, if it works on another computer then your floppy drive might be bad, if you built the computer, try using another cable for the floppy drive, i ran into problems like that when i put bad cables in
Dec 04, 2008 | Microsoft Windows XP Professional
Does any one have gateway GT5220 Installation disk ?
Create an ASR Floppy Disk loadTOCNode(2, 'summary'); The following steps can create an ASR floppy disk from an ASR backup operation: 1. Format a 1.44 megabyte (MB) floppy disk and insert the disk into the floppy disk drive of the computer. 2. In System Tools, start the Backup program. When the Backup and Restore Wizard is displayed, click Next. 3. Click Restore Files and Settings, and then click Next. 4. In the What to Restore dialog box, select the media that contains the ASR backup. Ensure that the media is inserted. 5. Expand the Automated System Recovery Backup Set that corresponds to the ASR floppy disk that you want to create. 6. Expand the second instance of the drive letter that contains the system files. Expand the Windows_folder/Repair folder. 7. Click the following files from this repair folder: Asr.sif and Asrpnp.sif, and then click Next. 8. At the Completing Backup or Restore Wizard screen, click Advanced. 9. At the Where to Restore screen, set the Restore Files to: dialog box to Single Folder, and then set the Folder Name dialog box to the root of your floppy drive, for example, "A:\". 10. Click Next. The other options in this wizard are optional and do not affect the transfer of files to the floppy disk. When the wizard is finished, the files are copied to the location that you had previously specified. The ASR floppy disk is ready for use in the event of an ASR restore operation.
NOTE: The Asr.sif and Asrpnp.sif files must reside on the root of the floppy disk drive to be used during a ASR restore operation. Starting the Windows Recovery Console loadTOCNode(2, 'moreinformation'); To start the Windows Recovery Console, use one of the following methods: • Use the Windows Setup floppy disks or the Windows CD-ROM to start your computer. At the "Welcome to Setup" screen, press F10 or press 'R" to repair. After you start the Windows Recovery Console, you receive the following message: Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
Type EXIT to exit the Recovery Console and restart the computer.
1: C:\WINDOWS
Which Windows Installation would you like to log on to
(To cancel, press ENTER)? After you enter the number for the appropriate Windows installation, Windows will then prompt you to enter the Administrator account password.
Note If you use an incorrect password three times, the Windows Recovery Console closes. Also, if the Security Accounts Manager (SAM) database is missing or damaged, you cannot use the Windows Recovery Console because you cannot have correct authentication. After you enter your password and the Windows Recovery Console starts, type exit to restart the computer.
When you use Windows XP Professional, you can set group policies to enable automatic administrative logon.
Use the Winnt32.exe utility with the /cmdcons option to add the Windows Recovery Console to the Windows Startup folder. This procedure requires approximately 7 megabytes (MB) of hard disk space on the system partition to hold the Cmdcons folder and files.
Aug 02, 2008 | Gateway GT5220 PC Desktop
Problem with disk drive A:
First, you should try to keep the floppy drive. If you can find one, I highly recommend getting the floppy drive cleaner diskette. They're hard to find now, but it's worth it if you want to continue to use your floppy drives. If cleaning it doesn't resolve the issue, next item to try is replacement of the floppy drive. You can borrow a floppy drive from someone, plug it in and test to side if it fixes the problem, if not, then it's either a motherboard issue (which I doubt) or a software/windows XP problem (more likely of the two). In which case I would recommend reinstalling windows XP to see if it fixes the problem before shopping for a new motherboard or a new computer.
Good luck
Jun 29, 2008 | Dell Dimension 2350 PC Desktop
Citizen 1.44MB 3.5-Inch Floppy Disk Drive (Beige) (LR1043) Floppy Drive Logo
397 people viewed this question
Top Citizen Computers & Internet Experts
NOEL
NOEL
john h
mtranch
Level 1 Expert
Are you a Citizen Computer and Internet Expert? Answer questions, earn points and help others
