Question about Indesit 24 in. IDL700 Built-In Dishwasher
  • 236 Answers
Chances are the element has gone or the heater relay on the pcb has blown. does the d/w pause during the cycle?
Posted on Feb 16, 2008
Indesit IDl705 flashing lights 1+2 during heating cycle and will not carry on. Have checked pump and all is fine, also checked float device.
If a machine cant do what its trying to do then it wont carry on. It will just sit there.
If its doing this while its supposed to be heating then my money is on the heater being at fault.
Oct 26, 2011 | Indesit W 123 Front Load Washer
I have Indesit IS70C dryer and all of a sudden it's not getting hot when switched on and the water container is empty..water is not draining from the clothes to the container and machine is not getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Jul 25, 2011 | Indesit IS70C Electric Dryer
Need to reprogramme memoery buttons
Please let us know the brand and model number of the phone.
Thanks for using FixYa.
Mar 22, 2010 | Lands Phones
Indesit idl 40 model, leaves dishes dirty and a dirty film on glasses.
First check if you are getting enough water into the DW, by opening the door after the fill cycle and see if you have about 1/4-1/2 inch of water by the edge of the tub. check that the water in the DW is hot (higher than 120 F) last, you may have a box of old DW detergent
Jul 20, 2008 | Indesit Dishwashers
Flashing star sign
Try turning off the breaker to it for a few min… and then turn it back on that might reset it.
Nov 07, 2007 | Indesit 24 in. DE73 Evolution...
If the water does not get hot, I assume the machine does not complete its programme? Since you have changed the stat, AND checked the element I think the timer may be faulty.
OR has a wire burned off in the heater circuit somewhere? You can test for a 240 volt supply at the two ends of the heat element with a meter, or even a 240 volt bulb.
!!BE CAREFUL!!  !!OF 240 VOLTS !!
Oct 31, 2007 | Indesit W 123 Front Load Washer
Sounds like an water inlet valve problem
Jun 28, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl705
this sounds as though it is in "flood mode" and may have a water leak into the base. unplug unit and check for leaks by tipping the dishwasher at a 45degree angle backwards and seeing if any water seeps out from the base. if it does you have a hose/ pump / seal leak.
Jun 06, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL700 Built-In Dishwasher Logo
165 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
