Question about Dymo LabelWriter 400 Turbo Thermal Printer
Dymo Labelwriter - Compatible Labels
Can you help please - I am looking for a Dymo Labelwriter printer - the Dymo labels for these printers are really expensive and so i want to be able to use compatible labels...can you tell me which are the latest machines available that I will be able to use compatible labels on?...the reason i ask is that I dont want to get the latest machine so I am forced to use only Dymo originals...can you help?
many thanks Nina
Printer says its out of paper after replacing it I still get the same message
Posted on Oct 05, 2009
    Problem Solver:
  • 14 Answers
All LabelValue.com compatible dymo labels will work with the latest Dymo printers. There is also a 20 instant rebate on the Labelwriter 400 Turbo when purchased from LabelValue.com between March 25th and March 27th 2008.
Posted on Mar 24, 2008
  • 3 Answers
Nina try www.labelvalue.com for Dymo labels and Dymo compatible labels. The shipping is also free.
Posted on Feb 22, 2008
  • malliso Feb 22, 2008
    I should add the compatible labels work with all Dymo Labelwriter machines some of the larger labels do not work with the 320 300 models that are over 5 years old
I have a dymo 450 and it keeps printing 2 labels each time. Is there a setting off?
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
You may have to disable bidirectional support: right-click the printer > Printer Properties > Ports > uncheck the option. ^CM
Sep 26, 2013 | Dymo ® LabelWriter® 450 Series PC...
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
We have recently printed and applied hundreds of asset sticker labels on our Dymo LabelWriter 450 and they have all faded! Is there a solution to this? or is the Dymo LabelWriter only useful for temporary...
LabelWriter labels are sensitive to sunlight. The coating is what allows to burn text onto them because LabelWriters do not use ink.
They are not supposed to fade easily so it may have been an old roll. Please contact our help desk for a resolution (see dymo.com for contacts).
^CM
Feb 10, 2011 | Dymo ® LabelWriter® 450 Series PC...
With Dymo Labelwriter 450, Can labels be printed in WORD without going through Dymo V8 software? I can print in Word but labels come out in portrait format and not landscape
They can. You may want to use the Word add-in for this. Please contact our help desk for further information (see dymo.com for contacts).
^CM
Jan 21, 2011 | Dymo ® LabelWriter® 450 Series PC...
We need firmware 93176vOT or 93491vOT - - - - - - - - - - - - - - - - - - - - - Dymo Labelwriter 400 Turbo bought in Europe with firmware blocked for use of original Dymo labels. We need firmware 93176vOT...
I couldn't find any information on the firmware version numbers, but I did find a site that might be able to help:
http://global.dymo.com/enNZ/HowTo/LabelWriter_400.html
You might try to contact Dymo Support, on the same link.
Good luck, and hope this helps.
Sep 22, 2010 | Dymo LabelWriter 400 Thermal Printer
There doesn't seem to be any ink - labels come thru' blank, all connections are good
These Dymo LabelWriters are thermal printers which uses heat to print the labels, not ink. Be sure you are using labels compatible with your Dymo printer.
Dec 29, 2009 | Dymo LabelWriter 400 Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Continual feeding of labels?
the settings of the printer must have been changed
May 20, 2008 | Dymo LabelWriter 400 Thermal Printer
Consistantly Intermittent Connection Problems
If you've tried installing the latest drivers and the problem persists it sounds like you have a lemon. The printers have a 2 yr warranty, so I would contact the retailer you purchased from and replace the printer. If your labels are jamming. Try the compatible File Labels available at LabelValue.com. They have both the Dymo 30327 and Dymo 30277 labels in a compatible version.
Feb 29, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
727 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
