Question about Sony PlayStation Portable (PSP) Console
PSP Connection Problems
When I connect my psp to my PC, I get the message "USB Device Not Recognized", I have also tried troubleshooting the problem on my PC and it will not find and drivers to install onto it, I'm running out of ideas and no one seems to have the same problem. (Yes I did go to USB Connect under the PSP settings)
  • Anonymous Apr 12, 2008
    ya i hav the same problem
  • rsiguien Sep 12, 2008
    I have the same problem too. I tried updating the driver for unknown device using "automatically search for driver from my pc and and from the internet" but it did not find the driver. In fact, I got the "no updates required for your device, latest drivers has been installed" kind of message. My psp usb connection works fine when connected to a different computer. Only with my Vista laptop I'm experiencing this problem. I tried using PCpitstop driver alert program but it did not find the problem. It suppose to scan the lacking driver for my usb. Can anyone help? Please? Thank you.
    Sergeant:
    Champion:
  • 322 Answers
Ok you need to invest in a hub carrier with it own power sorce as the psp and mp3 need 2.0 ? but the outher solution is to try a nother usb cable
Posted on Feb 15, 2008
Laptop will not recognize psp
Hi lawolf77,
If your laptop wont recognize your PSP there might be a connection problem between the two. So you need to check what's causing the problem. There are several ways to check if PSP and your computer are properly connected, one good example is by checking the connectors and the device setting.
If you want to check some configuration on how to connect your PSP to your PC please try to follow these steps:
1. First, connect your PSP to your PC using a usb cable.
- please make sure both ends are properly intact.
2. Using the left and right directional button find "Setting", then scroll down or up to find the "USB CONNECTION".
3. USB CONNECTION will display after you pressed the x button.
4. Please wait until computer detects the USB connection. After that it will show the drive for your PSP. usually F: or G:
5. Click on your PSP drive letter.
6. Now you can determine if your PC recognizes the PSP, just access the root folder and try to put some files on it.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
My psp wont connect to my PC? i tried almost everything please help!
Hi dominic_prig,
Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. --> Alsomake sure the Memory Stick PRO Duo has been formatted for PSP. 2. Connect the PSP to your PC with a USBcable. 3.Press the "home" button on the PSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Jan 09, 2011 | Sony PlayStation Portable (PSP) Console
PSP Not Connecting to PC via USB
Hi rupasam,
Based on your concern, I suggest trying the following steps:
1. Before you plug it in make sure the PSP is in USB connect mode.
--> Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's not this is how you do it:
On the main menu, scroll all the way left to the "Settings" menu. Then select "System Settings." Then scroll to "Format Memory Stick" and press X.
2. Connect the PSP to your PC with a USB cable.
3. Press the "home" button on the PSP
--> at the lower left of the screen you can see the home button.
4. Use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
5. Press the "X" button, your PSP should display "USB Connection".
6. Please wait until your computer tells you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
7. Click on the drive letter that corresponds to the PSP unit.
Hope it helps,
May 29, 2010 | Sony PSP (Piano Black)
When I plug my PSP (type A) into my PC (Windows XP
Make sure you follow these steps, this will allow the PC to recognize the PSP:
First make sure you have a USB cable that looks like this:
Then do this:
  1. Connect the mini connector to the top of your PSP and the other end of the cable into a USB slot on your PC. For the best perfornance, connect your PSP to a USB 2.0 slot.
  2. Make sure the PSP is on.
  3. Scroll to the 'Settings' menu by pressing the left arrow on the PSP.
  4. Select 'USB Connection' using the up and down arrows on the control pad.
  5. Press the 'X' button.
  6. Your PC should detect the PSP device, and show it in Explorer as a new drive (for example, 'F:').
Nov 28, 2009 | Sony PlayStation Portable (PSP) Console
My PC cant find my PSP even im connecting with a usb device....
Sorry about this, your usb port on your psp could be possibly damaged. So you can use a memory stick on your memory card reader to do your data transfer. If you insist on using the usb connection then try seeing a sony repair personnel for this.
Regards
Aug 21, 2009 | Sony PlayStation Portable (PSP) Console
My psp cannot connect via usb mode
Hi rin1_02, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Apr 07, 2009 | Sony PSP-3000 Silver Console
PSP Driver
What are you trying to do with the PSP? Are you current with all updates?
Go here:
http://www.us.playstation.com/PSN/mediamanager/
Dec 25, 2008 | Video Game Consoles & Games
Usb device cannot be recognized
Go to control panel, Add hardware and continue the setup(first connect the PSP to the comp)if they ask whether the the hardware is connected? Say yes... and if this doesn't work try (if you got a cd with the PSP) to install the software if you have one...
Jan 11, 2008 | Sony PlayStation Portable (PSP) Console
PSP - PC Connection
try in the my computer mine is always there
Nov 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
