Question about Texas Instruments TI-86 Calculator
TI 86 How can I enter degrees minutes and seconds in a TI-86
  • rapture4eter Sep 21, 2008
    i am getting the degrees and minutes input,but i am still having trouble inputing the seconds portion. it must be able to do it because if i do a conversion from degrees to bearings the seconds portion of the bearing shows in the answer.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press "2ND" "MATH" "F3" to invoke the Angle menu.
Enter the number of degrees, press "F3", enter the number of minutes, press "F3", enter the number of seconds, press "F3", then press "ENTER".
Posted on Jan 17, 2010
How do i change the setting to degree?
Press [2nd][MODE] to enter the default setup screen. On the third line Radian, Degree, highlight degree and press ENTER. From then on, angle values will be interpreted as degree values.
Feb 26, 2012 | Texas Instruments TI-86 Calculator
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
Hey, how do you enter minutes into a TI-84? (I'm doing problems with degrees, and one has minutes added onto the degrees)
The notation for minute is a single quotation, ' . To access this symbol, press the 2nd key, then the Angle key. The single quotation mark is the second option on the menu that comes up after pressing 2nd+Angle.
Apr 08, 2011 | Texas Instruments TI-84 Plus Calculator
How do i enter 46degrees 15minutes into my ti-36x calculator?
Enter DMS (Degrees/Minutes/Seconds) values as D.MMSSs, using 0s as necessary:
  • D degrees (0-7 digits)
  • . decimal-point separator
  • MM minutes (must be 2 digits)
  • SS seconds (must be 2 digits)
  • s fractional part of a second
For example, enter
  • 46° 15' as 46.15.
  • 179° 9' 2.54" as 179.090254, note the 0s in front of the 9 and 2.
Before using a DMS value in a calculation, you must convert it to decimal with [2nd] [>DD].
Jan 13, 2011 | Texas Instruments TI-36 X Solar Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
Converting between Decimal Form and Degrees, Minutes, Seconds
Enter the angle in degrees-minutes-seconds using the single-tick (') for all three parts. Do NOT use the degree and second symbols. In my TI-86 manual, it's on page 285.
Jan 15, 2010 | Texas Instruments TI-86 Calculator
How do I find degrees minutes and seconds on my ti 84 plus?
On this family of calculators, you do as follows
  1. Enter the first number (degrees), ex:15
  2. Press [2nd][APPS] (ANGLE) to access the Angle functions
  3. Select [1: degree symbol] [ENTER]
  4. Main screen shows 15 deg
  5. Enter the minutes, ex 25
  6. Press [2nd] [APPS](ANGLE) to access Angle functions
  7. Select [2:' apostrophe] [ENTER]
  8. Screen echoes 15 deg 25'
  9. Enter the seconds number, ex 32
  10. Press [ALPHA][+] (") to access the double quotation mark.
  11. Screen echoes 15 deg 25' 32"
  12. Press [ENTER]
  13. Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 11, 2010 | Texas Instruments TI-84 Plus Calculator
How do i enter 35 degrees 20 minutes into my TI-81 calculator
As far as I know, the TI-81 doesn't have a degree-minute-second entry mode the later TIs have. But to answer your question, you can always do it as:
 35 + 20 / 60
followed by ENTER if needed.
If you're in Radian mode instead of Degree mode, you'd have to follow up with MATH 6 to specify degrees instead of radians.
Sep 29, 2009 | Texas Instruments TI-81 Calculator
Degrees, minutes, seconds converted to decimal degrees
No DMS button
1degree 22.25 minutes
2nd Math F3 1 F1 22 f3 15 f3 enter
Sep 05, 2008 | Texas Instruments TI-85 Calculator
Minutes
Yes. Use the following procedure to enter an angle in degrees-minutes-seconds form:
Enter the number of degrees. Press "2ND" "ANGLE" "1"
Enter the number of minutes. Press "2ND" "ANGLE" "2"
Enter the number of minutes. Press "ALPHA" " (double-quote above the +)
The ANGLE key is the APPS key.
Aug 19, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-86 Calculator Logo
419 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
