Question about Zenith ZEN450 Remote Control
Zenith data systems Z-note 325L
I just received un Z note 325L.
It seems a disquette is necessairy to boot?
Isn't there a hard disk in this device?
What must be on this disquette?
Thank you very much.
Jean Moulaert
ISL institute
Reset my fujitsu laotop model M6210 back to factoy reset
RESTORING THE FACTORY IMAGE
The Restore Disc that came with your system contains
two utilities:
? The Recovery utility allows you to restore the original
contents of the C: drive.
? The Hard Disk Data Delete utility on this disc is used
to delete all data on your hard disk and prevent it from
being reused. Do not use the Hard Disk Data Delete
utility unless you are absolutely certain that you want
to erase your entire hard disk, including all partitions.
BOOT Priority Change
Before restoring an image, you must first verify that your
system is set up to boot from the DVD drive. To verify/
change the boot-up priority (rather than booting-up
from the hard drive or an external floppy disk drive),
perform the following steps:
1. Start your system and press the [F2] key when the
Fujitsu logo appears. You will enter the BIOS Setup
Utility.
2. Using the arrow keys, go to the Boot menu.
3. Arrow down to the Boot Device Priority submenu.
Press [Enter].
4. If "Optical Media Drive" or "CD-ROM Drive" is not
at the top of the list, arrow down to the drive in the
list, and press the space bar (or the + key) to move it
to the top of the list. (The system attempts to boot
from the devices in the order in which they are
listed.). Note that the BIOS for some systems will
indicate "CD-ROM Drive", even when a DVD drive
is connected. Then put in DVD restore disc that came with the computer and follow its instructions.
• This disc can only be used with the system with which it was purchased.
Fujitsu IT and Business Services IT Consulting IT and Business Solutions
Feb 19, 2015 | Fujitsu Computers & Internet
I need to format my pc
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
hope this helps
Oct 17, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Reformat a gateway nv5207u
hope this helps
Oct 14, 2012 | Computers & Internet
How to format hard drive
hope it helps
hope this helps
Aug 02, 2012 | Samsung HM060HI Hard Drive
How do i format a sata11 hard for use in another pc in windows xp pro 32 bit
hope this helps
Jul 12, 2012 | Western Digital Caviar Computers &...
I need to wipe a hard drive clean of os and data and reinstall new info
Have a Operating System disk ready to insert to DVD or CD device. Go to boot menu or boot first menu making sure that your booting from the DVD or CD device as the first boot. Generally this is the Default setting in most machines. Go to BIOS if you cannot access the boot order menu at start up. Tick on boot and select that option second device will be the HD or whatever is noted for your hard drive.
Place the disk into the drive boot and follow the onscreen instructions. John
Apr 17, 2012 | Toshiba Satellite A55-S106 Notebook
How do I reformat my harddrive using widows xp
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
Hope it helps you
Apr 11, 2012 | Microsoft Windows XP Home for PC
Good morning. I have a question regarding hard disk WD5002ABYS that's running on a Cisco DVR for surveillance (CIVS-GM-ISP12-6TB). I need to reformat all the drives on it, 12 in all. How do I that?...
you have to format your hard drive using a third party disc to erase everything on your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
also you might use a disk wipe utility
http://majorgeeks.com/Free_Disk_Wipe_d5309.html
Free Disk Wipe data cleanup and file wipe tool, that allows you to completely wipe/ remove / delete / erase a selected file(s) on most disks (floppy disks, hard disks, logical drives, etc).
Data recovery software can
Jul 14, 2011 | Western Digital WD RE3 WD5002ABYS hard...
I have several hard drives that came out of non working computers,how do prepare these to work in another computer?
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also
Jun 25, 2011 | Computers & Internet
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
Sep 02, 2009 | Computers & Internet
Zenith ZEN450 Remote Control Logo
145 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
