Question about Motorola Mobility V600
Cell's Display is Blank
I can dial numbers and make calls and receive calls, but my display is blank. I have taken the battery out and replaced several times, but I cannot get it to display anything.
  • 1 more comment
  • tigirl Feb 18, 2008
    It has been dropped several times. When you try to turn it on the only the number pad will light up.
  • tigirl Feb 19, 2008
    Thank you very much :)
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Was it dropped recently?
    - Jim
  • 2,130 Answers
It's possible that the flex cable that connects the display to the main board has become loose or disconnected. This could easily have happened if the phone was dropped.
The worst possible scenario would be a damaged LCD display due to being dropped.
Unless you feel comfortable with taking the phone apart, you will need to take it to be serviced.
You may also wish to find out whether its cheaper to replace the phone rather than paying to have it fixed.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 18, 2008
My screen is blank-- i can make calls by dialing the number, or receive calls but can't see anything (so cant see/send texts or know who's calling). HELP? either how to fix it or how to I forward texts...
hi
first you should restart your phone.if you still have same problem means there must be fault in display screen.you should change the display screen of your mobile.but make sure that you should go to your company service.because there are local salesmen they will change old displays .just change the display screen of your mobile
thank you
Dec 17, 2010 | Verizon Communications LG Chocolate Cell...
My phone has a blank screen
Are both displays blank, or only one? Is there any backlighting coming on? Any cracks visible? Was there any damage (dropping, etc.) that you remember around the time they went blank?
If you determine that your phone is actually turning on, do the other functions of the phone work? In other words, can you dial a number and hit "Send" and successfully make a call? Can you get sound out of the external speakers by pressing the little "speaker" key at the lower right of the inside keyboard?
If everything seems to work and the ONLY problem is the displays being blank, it is possible to replace the display module. If you have some electronics experience, and you are considering doing it yourself, see this thread for a little more detail about my experience (I did it successfully.) But you'd want to know that the display is the *only* problem before committing to replacing it.
Otherwise, there's not a lot of repair you can do on these things yourself.
Jan 31, 2010 | LG enV3 VX9200 Cell Phone
N70 DISPLAY IS BLANK/WHITE
Its a display IC fault.heres the screenshot..replace this two crystal IC for display.9323da0.jpg
Jul 21, 2009 | Nokia N70 Cellular Phone
6310i has blank screen
sir if ur display is ok then just clean the pcb and display connector with pcb cleaner or molycote it will work its been tested
Aug 22, 2008 | Nokia 6310i
Blank Screen
6300 blank display what to do
May 14, 2008 | Cell Phones
Display blank, no keypad tones, Emerson EMG900 phone
you must use a ac adapter which the phone doesnt come with or 3 double A batteries
Dec 16, 2007 | Emerson EMSEM2646WH Phone
Display Issue
format once before that u back up the phone memory in memory card ... And to format switch off the phone and again switch on the phone simultaneously pressing the dial key ,* and 3 ... u'l get a black screen called formatting ...
Dec 03, 2007 | Nokia 7610
Main screen blank
Same problem here...must be a bug with the phone or has to do with DST..Appears all E815's will not work.
Oct 23, 2007 | Motorola Mobility E815
Motorola Mobility V600 Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
