Question about Denon D-C30 Shelf System
Denon D-C30 Hello, Lost in house move, speaker cables for Denon HiFi System. Could you please advise the type of speaker cables required for this specific system.I have no idea about electrical connections and am lost without my system. I know this is probably a simple solution but l am without knowledge so therefore your help would be much appreciated. Anne
I dont know this system specially, but the speaker cables are usually heavy double cables with plugs on each end.
I would suggest that you visit a Dick Smith store and ask to see what speaker cables they have available...they are pretty standard its just the length and the plug socket match you need to make for the Denon model you have,
Cheers From YUBEUT
Posted on Feb 15, 2008
The speaker cables has "banana
If they're a fixed spacing that doesn't match the spacing of the black and red speaker terminals you'll need to either chop them off and replace them with individual tips or just wrap the twisted bare wire ends around the base of each post and crank 'em down. Make sure no strands are touching anything but the intended post.
http://www.hdwise.com/product.php?productid=522
http://www.flickr.com/photos/frankharveyhifi/4617863847/
14-gauge lamp cord still works fine.
Mar 06, 2011 | Denon DM38S Audio Shelf System
Just bought a denon, and wharfdale 9.1 speakers with no rca cables, what rca cables do i need?
What model speakers?
Didn't these things come with manuals?
Speaker connections from the Denon are typically through speaker cables (glorified lamp cord).
The Denon is not capable of driving the sub directly. The powered (?) subwoofer in your setup would presumably require an RCA cable (whatever length reaches) to feed its amplifier a bass signal from the Denon's Subwoofer Out.
Mar 23, 2010 | Denon AVR-2105 Receiver
Mistracking on dvd player
Hello!
It turns out there is a problem using hdmi cables with integrated amplifiers Denon dvd players (the 1940 series) - the hdmi cable processes the visual signal before the audio signal. Therefore there is what appears to be a lip syncing problem because there is a short 'time delay' between the visual and audio signals. I would advise anyone to simply use an AV reciever as they incorporate time delay technology so the visual and audio signals are in perfect sync. Luckily, Richer Sounds, where I bought the intergrated amp gave me a full refund, no quibbles or hassle. I would like to add I am unsure if the problem lies with just the Denon 1940 hdmi dvd players and intergrated amps or ALL hdmi players. Also, I was trying to achieve a simple 2 speaker set up with the amp.
The forum on What Hi-Fi document this problem with much better clarity and technical explanation that my understanding of the problem. However, the lesson learned is, if you want any speaker set up with your dvd player, use a dedicated AV reciever.
Best Regards, Graeme Young.
May 17, 2009 | Denon DVD-1940CI DVD Player
How to change speaker yamaha keybord
Simply put, the speakers can't be changed on Yamaha keyboards. If you have blown the speakers then put the sound through an amplifier or HIFI speaker system - but you must be able to have an AUX cable and AUX on the HIFI for this to work. Sometimes it can also work by use of composite cabling too, depends really on what audio equipment you have.
Apr 02, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Denon AVF988 to power amp to whole house speakers
jbell302, Check both remote spkers for operation from the A spks output if good, switch B remote spks to A main connect & main A spks to the B remote connection on the Denon spks outputs . Most amp sources do not like different ohm spks types & different cable or spks A-B. lenghts, because this makes up to resistances problems, making the amp to work harder & understanding what is going on. THE AMPS PROTECTION CIRCUIT IS AT ALERT & TRIES TO BALANCE THE RESISTANCE VOLUME. Best move is to try use the same spks. lenght & a higher qauge wire; 12.14.18qa. to better balance the output volume! All matching spks. pairs would help alot as well!
Feb 04, 2009 | Denon AVR-3805 Receiver
Hello, I need replacement speaker terminals
Please let me know connectors color at back of unit to provide you info for speaker cables.
Nov 29, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Denon D-90 Hi Fi - have lost interconnetion leads
Gents - not sure where you live, but try these UK links. The D65 was a similar system produced a year or two earlier, if the cable is 15 pin my bet is it is the same cable. Good luck, better look after my cables carefully!
http://www.chsinteractive.co.uk/electrical-components/misc/d90-cable-system-connect-13pin.htm
http://www.chsinteractive.co.uk/electrical-components/misc/d65-cable-system-connect-15p-d.htm
Nov 18, 2008 | Audio Players & Recorders
I need help in connecting my audio video system correctly once and for all.
http://www.retrevo.com/s/Denon-AVR-1803-Receivers-review-manual/id/363bh838/t/1-2/
please have a look in user manual above.
regarding your dvd check for yellow socket named dvd video in----or change your video cable.
Feb 08, 2008 | Denon AVR-1803 Receiver
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
285 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
