Question about Phonic - XP 5100 - 5000 Watt Power Amplifier with Subwoofer Output Amplifier
May i have a diagram of audio amplifier of phonic xp 5000
  • 1,512 Answers
You can download one direct from the OEM guys in China, but it will cost you( US$2 it appears) http://www.icxinyi.com/EN/
Best I could find. Good Luck
Posted on Feb 15, 2008
Where do i take my amp for repairs
- SEARCH ENGINES ARE YOUR FRIEND!!! Type your info into a good search engine (Webcrawler is dandy) and check the results.
- You can be sure that you aren't the only person in the world who has had this problem - should be help out there somewhere.
Good Luck :)
R
Feb 06, 2015 | Phonic - XP 5000 - 5000 Watt Power...
Repair manual phonic mm102a
You are unlikey to find a repair manual. Phonic is a pupolar low-end brand, I believe it is manufactured in either China or Korea, but their website is careful not to say. Any decent repairr shop should be able to trace down problems and obtain parts, or if you are really adventuous, youo can pose around yourself, but use caution around high voltage and static-sensitive components.
I wish that I could offer more, but sadly, they are not a "major" brand.
May 27, 2014 | Phonic - XP 5000 - 5000 Watt Power...
Can phonic xp 5000 or xp 5100 amplifier use 220 volts?
Hi i have a phonic mar 6 its clipin at low volume what could be the problem
Feb 01, 2011 | Phonic - XP 5100 - 5000 Watt Power...
Hello, i need phonic max 2500 plus diagram
  • 860/1500/2500 MAX 860/1500/2500
    archive.espec.ws/.../PHONIC%20MAX-%20860%201...
    Traduire cette page Phonic reserves the right to improve or alter any information supplied within ... MAX860/1500/2500 SERVICE MANUAL ..... HEAT SINK MAX SERIES PHONIC.
  • PHONIC max 2500 - Service Manual free download ...
    www.eserviceinfo.com/index.php?...PHONIC+max+2...
    Traduire cette page 15 janv. 2009 - Search results for: PHONIC max 2500 (found: 50 regularSearch) ... Audio, 2891 kB, 2178, Service Manual, PHONIC max 2500, VASILICH500.
  • Amplifiers :: Analog :: MAX 2500 Plus - Phonic ...
    www.phonic.com > Home > Amplifiers > Analog
    Traduire cette page Phonic's MAX 2500 Plus Power Amplifier provides 1500 Watts of power at 8 ohms (bridge mono) or 750 ... MAX 2500 Plus Simplified Chinese User's Manual.
  • PHONIC MAX 860 1500 2500 Service Manual free ...
    elektrotanya.com/phonic_max...2500.../download.ht...
    Traduire cette page PHONIC MAX 860 1500 2500. Sponsored link. Type: (PDF), Size 2.9 MB, Page 27, Category: AUDIO - SERVICE MANUAL. Warning! If you are not fa
  • Nov 19, 2010 | Phonic MAX 2500 Amplifier
    Problem in dc board fuses are open many times
    You have a major component failure in the power out section
    You'll need to replace quite a few transistors
    Aug 04, 2010 | Phonic - XP 5000 - 5000 Watt Power...
    What power in RMS have in 4 ohm y 2 ohms?
    Your question is not very clear, The Root Mean Squarre power is the determined power available from the amplifier's outtput according to the design. The output delivery for 2 ohms will be double that of the 4 ohms. hence the rated speakers sufficient for the load must be given to prevent damage to the speaker orr the amplifier. Hope this helps you to guide . Good day
    Jul 17, 2010 | Phonic - XP 5000 - 5000 Watt Power...
    The amp makes overload protiction while no sound
    if the input signal is very low check output cables for good condition and no wires from cables touch the amp chassis--no touching between each cables-check each speakers one by one to isolate the trouble-if everything is ok and you still get overload protection you must pass it to service center.
    Dec 26, 2009 | Phonic - XP 5000 - 5000 Watt Power...
    Phonic XP5000 problems clip ligth coming on and killing input
    Don't buy a Phonic XP5000 similar to the Crown XLS5000. Probably share the same problems. I tried three XP5000 that all had the same problem.CheersRob UeberfeldtKaikohe New Zealand
    Mar 18, 2009 | Phonic - XP 5100 - 5000 Watt Power...
    Manual
    Hi - You can download the manual from the link underlined in blue below:
    Phonic MM 1002
    Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
    Informatica
    Aug 20, 2008 | Phonic - XP 5000 - 5000 Watt Power...
    Phonic - XP 5100 - 5000 Watt Power Amplifier with Subwoofer Output Amplifier Logo
    621 people viewed this question
    Top Phonic Audio Players & Recorders Experts
    Greg Cann
    Greg Cann
    tom8341
    Level 1 Expert
    Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
