Question about Zenith A27A11D 27" TV
No Red- Intermittent
Wondering if this is worth fixing. TV has a good picture but there is no red, just Blue and Green. Every once in a while the red comes back but then goes out. TV was no dropped. Problem just started and TV is almost 10 years old. Is it worth it to fix?
  • Litmany Feb 20, 2008
    Just spoke with the repair place and they said the picture tube is bad and would cost more than a new TV to fix. So back to square. Is it worth a second opinion?
    Brigadier General:
  • 6,966 Answers
A short answer, YES. I suspect a cold solder on the red drive transistor. That transistor is one of 3 identical components (one for each of the blue & green). They are normally found in a small squarish PCB that is connected to the rearend of the picture tube. In some instances, they are also heatsinked. More often you need to remove the shield/screen protecting the foil side of the PCB. This has to be done gently since it can easily crack the glass holding the pins.
Cold Solders are corrected by applying heat from a soldering iron and probably a dab of solder lead. Solder joints should be shiny (not dull gray) with no air bubbles.
If your concern has not been corrected after completion of the above procedures, you may need to replace the red drive transistor. it might also be worth your while to check for any other component that may suffer from cold solder and/or any loose connection(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 15, 2008
  • Louie  Role
    Louie Role Feb 15, 2008
    A friendly reminder pls. Extreme care should be exercised since you would be working on components with high voltages. The TV has been known to hold such a charge even when unplug.
    The above procedures calls for a bit of knowledge and familiarity with electronic components and circuitry and of course soldering. Should you not be comfortable doing this, perhaps you need to seek the services of a qualified professional or at least a friend who has done some electronic work/soldering before.
    Cheers.
  • Louie  Role
    Louie Role Feb 22, 2008
    Hi again,
    Your own opinion should be good. Give it a gentle "whack" on the side. If the red comes back (even for just a while), it is a loose connection, if not guess they're right, replace the TV.
    Cheers.
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I heard a pop in the TV and then the screen went red. I can still hear it and watch it but everything is red. Is it a bulb that needs replacing? If not, what is it? Can I do it myself or will I have to...
Several failures can cause a red picture but it sounds like if you are connected from the source with component video cables(red,blue,green)you may just have a bad cable,but you may have had a blue and/ or green projection gun failure,which would cause the red gun to over power the other colors(blue/green), if this is the case definently not worth the cost to repair, you have to replace all three guns at the same time costing $500+ to repair, invest that towards a nice new LCD panel TV. Good luck !
Nov 26, 2009 | Akai PT5492S 54" Rear Projection...
I have sound but the picture is purple and will not adjust with the remote or manually with the buttons on the tv what can I do to fix this on the philips 36pt41b129
The unit has lost its green video information. This can be a picture tube or a green drive problem. The only colors you are getting are red and blue thus the purple picture. All picture tubes have red, green and blue guns to make all the colors needed for a normal picture. It will take some troubleshooting to determine whether it is a drive problem or the picture tube itself. Have a repair shop check it out for you. A 36" TV is worth a check out fee. Thanks for using Fixya. Let me know how it goes.
Nov 05, 2009 | Philips Televison & Video
Double lettering on red when in 1080i good picture in 480p
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips 55PP9401 55" Rear Projection...
Green/Blue distorted Colors
Color issues are harder to solve without seeing the problem. It sound like the red amplifier on the crt board is bad. Is there any red in the picture at all? If not, that will be you problem
Nov 26, 2008 | Televison & Video
Your TV question
Have you replaced both of your STKs if not do so this will repair set.392-020s up grade with 040s if they are 110s, 150s go to the 180s.
Oct 31, 2008 | Philips Magnavox 51MP392H Rear Projection...
Samsung sp42w4hb rear projector tv
Dave,,yes the tv is worth fixing the ic part you need is STK 392-010 and at this site i will give the link to they are 19.99 each you will need 2 if you get them at the link I posted you will also get free online tech support plus installation instructions with pictures
http://servicemanuals.vstore.ca/
Apr 09, 2008 | Televison & Video
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
My TV has blue lines,flashes then turns off
Bad blue CRT common problem.....................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
