CGA5722 - Boxed in "A
CGA5722 - Boxed in "A complete wireless network ---". Box states it's a CKA 5720 Starter Kit - purchased Tescos 14/2/08.Signal Scale in Notification Tray shows red X & states "Network Disable" TV screens alongside say "Currently connected - Network 2 - Local & Internet"
My laptop is connected wirelessly with key & home PC with the ethernet cable to from Lan 1 to ethernet connection on PC. Windows Home Premium on home PC & Home Basic on laptop. Both have working internet connections.
  • Chris Busch
    Chris Busch May 11, 2010
    Make sure your wirless router is set with a wep key and broadcasting, on the laptop you should set those to the same and it should connect, some laptops have a way to turn off the wireless from the keyboard, usually by holding a fuction key and pressing an F key that shows a picture of a tower on it or something similar. when you right click and select " view wireless connections" are you able to see your wireless router or does it say " no wireless available"? are you using Windows wireless Zero configuration, or does the laptop us eits own program?
    Problem Solver:
  • 22 Answers
Can you a little bit describe what other device that you are using. maybe access point. Are you using an access point?, or switch?
Posted on Feb 17, 2008
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
I just bought the NetGear wireless adapter today. the process runs smoothly until it asks me to hook the wireless adapter. A box pops up stating "detecting wireless adapter" it stays like that...
It looks like your NetGear WNA3100 is dead out of the box.
The software looks like it operating correctly (runs the installed diag, tries to detect, etc.), but
the software isn't having any luck finding the hardware.
The reason that the adapter is disabled in Device Management, is that the software seems
to have correctly installed the driver, but Windows couldn't detect (plug & play) the device, so
Windows didn't enable the device driver - Windows won't load a driver for a non-existent device.
Other (remote) possibilities:
(a) Wi-Fi adapter plugged into a bad USB port. - try another port.
(b) there's a little corrosion on USB contacts of USB port or WNA3100. Try plugging adapter
in and out of the port a few times (this shines up the contacts a bit).
(c) there's a slight misalignment of contacts within the USB connector or either the laptop, or
the WNA3100.
Your fix may be returning the NetGear WNA3100 to the retailer for an exchange.
Sep 04, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Motorola SBG901 installation CD on Vista 32 bit HP lap top error states "No wireless network adpter could be found please insert." Windows 7 laptop connected with no effort through the wireless...
it is a modem for cable. If you want to run your laptop you need the wep or wpa encryption key that is in the wireless 802.11 b/n/g part of the modem.
on the working p.c go to 192.168.1.0 in internet browser
type in user name of admin
type in password of motorola
do not change the settings as stated in the link below
just find out if ssid is broadcasting and what wi fi security is in use and what the encryption key is
http://setuprouter.com/router/motorola/sbg901/wifi.htm
https://kb.netgear.com/95/Configuring-your-wireless-connection-using-Windows-Vista-Wireless-Zero-Configuration-or-WLAN-AutoConfig-utility
Nov 28, 2017 | Computers & Internet
I just purchased a "wii" system and am trying to
The Default Password which is in the bottom of the Router is Case Sensitive. If it is Not working Please Follow the Following Steps to Check your Password.
- Connect your Computer using a Ethernet cable to any of the 4 LAN Slots on the Router.
- Open Internet Browser & in the Address Box Type the numbers: 192.168.2.1 & hit Enter.
- In the Setup Page Towards your Left Corner Under Wireless Click Security
- Leave the Password Field Blank & Click Submit.
- You will Find a Small Obscure PSK Box with an Check Mark Uncheck the Box.
- You will see your Password in Pre shared Key (PSK) Box.
- Try Joining the Network on your WII using the Password.
Mar 26, 2011 | Belkin Basic Wireless Router
I have a slyvania NB620SL1 blu ray player that is wifi enabled. I am able to find my wireless network and enter my WEP/WPA Key. It then tells me "Wireless router settings are incomplete. Please...
Had the exact same problem. Check your system setting on your router. See if you have a SSID broadcast check box, if it is unchecked, check it then try it.
Dec 25, 2010 | Televison & Video
Connect my Lynksys WRT54G2 Router with my Belkin (F5D6231-4)
You can connect 2 routers to each other. But the IP address will be different for both the routers .
It will be better to keep different names for the wireless network.
If you keep the same name, then it doesn't mean that the signal strength will be good. Because both the routers will broadcast their own signals.
If you want to increase the signal strength then you can purchase a wireless range expander.
Click Here for more info about the networking
Nov 04, 2009 | D-Link Wireless Starter Combination Kit...
How to enable WI-FI function on Compaq Presario 2500 lap top.
Go to "network connections"
It should say Local Area Network and Wireless network (if your card is installed properly). Right click the Wireless Network and make sure it is enabled. Then click "View Available Wireless Networks" and choose your network.
If you are trying to setup a secure wireless network, that may be a completely different issue.
Jan 27, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
I want to purchase crickets wireless broadband to use with my laptop and i need to route my home computer to use it also. i have a dell b 110 with intel pro 100 ve. what else do i need to purchase to use...
Any wireless router should do just fine. Make sure to purchase a Wireless G or N, should be clearly stated on the box before purchase. They run about $40 for a ok one. Very easy to configure to.
Good luck with everything and I hope I could be of some help.
Jan 15, 2009 | IBM Intel PRO 19K5710 Network Adapter
Dell Inspiron 1520
it'll not fit since your laptop needs an expresscard.
here are the list of the wireless cards that you can get:
Dell Wireless 1390 802.11g Mini Card Wireless Dell Wireless 1490 802.11a/g Mini Card Wireless Dell Wireless 1505 Wireless-N Mini Card Intel Pro/Wireless 3945 802.11 a/b/g Mini Card Wireless Intel 4965AGN Wireless-N Mini Card Dell Wireless 5510 HSDPA ExpressCard34 Dell Wireless 5520 HSDPA Dell Wireless 5720 EVDO or a Linksys Wec600n Wireless-N Expresscard Adapter
Jun 04, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Belkin wireless G USB adaptor 802 11g
Correct installation of this cheap little piece of kit from Belkin might be the worst thing you ever do! If you find that Windows XP is freezing 10 times per day, just remove the wirelss adaptor and you will find that the problem disappears... The conclusion will be as obvious to you as to many other users.
Jul 13, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
Computers & Internet Logo
148 people viewed this question
David Payne
David Payne
