-   the top sprayer arm in my dishwasher is not not working. It appears that no water is spraying out of the top and detergent was not dissolving?> -   agenett23
Feb 16, 2008
-   I have removed the tube from the bottom to the top, removed the screem covering the lower area and cleaned, can not get the cover off of the empeller of the pump.-   Guest
check water level in machine
may be not filling enough and the wash pump is starved from water thus not pushing water to upper arm
drain water from machine dismantle and clean out air tube to pressure switch take off air tube at pressure switch and blow back into sump then pinch air tube with fingers to stop air from flowing back up tube then refit to p/s
run and see if that solves problem
it does not let in water to the machine ,the sound is normal when its plugged on,the lights are on...
(More)
it does not let in water to the machine ,the sound is normal when its plugged on,the lights are on etc but it just wouldn't let in the water
I have a kitchenaid dishwasher, SS, model # KUDIO1ILBL6. When you press the ''normal'' button to run...
(More)
I have a kitchenaid dishwasher, SS, model # KUDIO1ILBL6. When you press the ''normal'' button to run it, nothing happens. Tried other cycles and same thing, the green light goes on above the cycle but its just not starting. I tried resetting by opening, pressing high temp scrub then energy saver dry, high temp scrub, energy save dry, then close and hit cancel. Is there any other combo to reset it? or does it sound like something else is wrong? thanks!
I have a 7 yr old KitchenAid undercounter dishwasher that was working fine, then it suddenly...
(More)
I have a 7 yr old KitchenAid undercounter dishwasher that was working fine, then it suddenly appeared to lose power: no lights and no response when buttons pressed. The circuit breaker is not the problem. Any idea what might be wrong?
