Question about Zyxel P660HW-D1 Router
I NEED SOME HELP
I HAVE FOLLOWED THE INSTRUCTIONS IN THE QUICK START GUIDE BUT CAN FIGURE OUT HOW TO GET TO THE SAVE BUTTON AND CONNECT THE ROUTER WHICH I AM USING THE WIRE LESS WAY PLEASE HELP.
  • 123 Answers
The first setup is usually done when you have the network cable plugged into the router. once configured you can unplug the cable and connect wirelessly...
Hope this helps...
Posted on Feb 15, 2008
Can not connect my TV to my router
Clear the arp cache in the router and TV. Use the automatic setup function on the TV (if available) and set the router to accept incoming requests.
Nov 29, 2014 | Computers & Internet
Where can I find my AOSS button on my Linksys router
What model?Push the Cisco logo to start SecureEasySetup The logo is lit with a reddish hue (the User Guide says this is orange) when the router powers up in its factory default unsecured state. The instructions say to press the SES button. But there is an approximately 8 second pause between the button push and three seconds of no light, followed by the rapid white flashing backlight that indicates the router is in SES search mode.
Jan 25, 2013 | Linksys Computers & Internet
I'm trying to install a new 628 router. The wizard won't work and I have no clue what else to do. I have connected the router as per the limited instructions in the quick set up guide but it's not...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Dec 04, 2010 | D-Link Computers & Internet
Unable to connect to the laptop computers
dear Sure there is, but it's supposed to connect via a LAN switch. Since it worked at your old place, did you miss a step? Was the printer plugged into a router and the computer also plugged into the same router?
Start with the wired network setup section in the quick start guide. It might give you an idea on what to do http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_490CW_EN_1578.PDF
Thanks.
May 07, 2010 | Brother MFC 490cw Color Inkjet...
Don't know how to get started using the wireless router to my internet service
On your computer,when you make your connection to the internet.If the prompts asks for "wire or wireless".And you push wireless if it only partially configures,then try to get the manufacturer.By writting,online,or by phone about your router' problems.
Feb 15, 2010 | Linksys Wireless-G WRT54G Router
Trying to figure out why i have to connect the blue wire to my laptop from the router, i want a wireless connection?
You do not have to connect your laptop to your router if you want to use it wirelessly.
For doing the initial setup for the router although I would definitely recommend to connect both with a cable and not doing it wireless.
The main reason is, if you setup your security (WEP or better WPA, idealy WPA2), you will loose instantaneously the connection to your router. You will have to copy the network key to your laptop to reconnect to the router.
Therefore: connect your laptop with an ethernet cable to your router and follow the instructions in the user guide (if you don't have it, you can get it here. Setup your router manually and don't use "Wi-Fi Protected Setup button" - that way you know what is happening. Choose a long security key (63 characters) for WPA (or WPA2, if your computer can handle that) and leave everything else on default.
Copy the network key into a text document and save it on your computer, so you have it handy when the router asks for it.
Unplug the cable.
Check if you can connect.
Reconnect the cable to your router.
Change your SSID and use MAC filtering, unplug and check again for connectivity.
If this helps you, please leave a comment here, because it might assist others too.
Dec 27, 2008 | Computers & Internet
ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
Sep 23, 2008 | Zyxel Prestige 660HW Wireless Router...
I have purchased a Dlink 300 router. I have put in the quick installation disk and followed all the instructions but keep getting a error message telling me that no router is detected? What could be the...
if u have connected your router then u dont need the driver of router or chage the lan card if has the problem then your router its not detacted or remove & reinstall the lan card driver then try to connect
Jul 29, 2008 | Computers & Internet
My Router won't even connect...
I had the same problem with ATT DSL. I hooked the computer back to dsl modem and verified that I was connected with a browser. I then hooked router back to modem and computer to router. It stayed connected. Might be you worth trying. Hope it works for you. Thanks.
Feb 22, 2008 | Digi ConnectPort (CP-WAN-A300) Router
Zyxel P660HW-D1 Router Logo
50 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
