Question about Sabrent (USB-2535) (USB2535) IDE Controller
Internal USB Card Reader
I have a Sabrent CRW-UINB and want to connect it internally to a Dell PC without a standard USB header on the mother board. Is there a PCI card, or adapter cable that will allow me to do this.
Most add-on USB2.0 cards have the standard USB header on them if you have the room for a PCI card.
Posted on Aug 08, 2008
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
USB Header
The only way is to purchase a USB Board to install in the PCI slot, but that would be overkill since you PC already has 4) 2.0 USB ports. I would exchange that internal reader for an external reader.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2400 PC Desktop
Internal USB connector
You did not have to unplug the onboard USB ports.
Your OS should see the card reader and set it up, unless you are using Win98 or WinME. I would plug the onboard USB ports, then restart with the new internal card installed.
Sep 26, 2008 | Dell Dimension 4600 PC Desktop
Imstalling internal card reader
Well, installing an internal card reader without a spot on the motherboard, is a little hard to do. I would suggest buying an external card reader. They are a little cheaper, and a lot easier to setup and use, since they just connect to a USB port which all computers have.
Feb 23, 2008 | Dell Dimension 3100 PC Desktop
Installation help for dynex dx-crd12 all in one card reader
I would recomend installing the card reader this way. Shut off all programs that you don't need during the start up. When the card reader installs its kind of touchy, froze my computer a few times.
If you have blue 9 pin usb headers on your motherboard, consult your manual for this, or google it. Take the 5 pin connector, find the side with the red wire, face that side away from the side of the blue header with a missing pin. Make sure you connected to the row with 5 pins. After that you should be able to power up your computer and it will work.
If your computer doesn't reconize the card reader use the cd it came with.
Nov 10, 2007 | Electronics - Others
Sabrent (USB-2535) (USB2535) IDE Controller Logo
179 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
WTF Chuck.....
WTF Chuck.....
Colin Stickland
Colin Stickland
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
