Question about Disney Mix Max Digital Media Player
Wont charge I have charged the mix max for about 18 hours. While charging, the battery blinks green. When I unplug it from the computer it won't turn on.
  • taintworking Feb 18, 2008
    I have the same issue...tech support never called me back...i suppose that it will have to go back to the manufacturer....I believe it is memorex
Did you send it back to the manufacturer?
Posted on Feb 18, 2008
There seems to be no solution to this. I have the problem to and the 1.888.800.0502 phone number is no help. If you have your receipt- TAKE IT BACK AND GET AN IPOD! That is really the answere.
Posted on Feb 15, 2008
Emerson emp287c-4 wont charge with usb
Having same issue, battery will not charge. Can't even use it unless its plugged into my computer the whole time. Followed the charging instructions, "turn power switch on and then use the usb cord provided to plug the device into the computer." I do so and it reads that it is charging, however the bar never goes to the green charge symbol. It said to not let it charge past 8 hours so I always unplug it before that. Even tried the recommended 3-5 hours and still I turn it on and it says right away battery low.
Dec 26, 2012 | Emerson Televison & Video
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
Disney MixMax player... JUST bought this device. I installed the software CD, but that is JUST for the online/media storage component... I plugged it into the computer & computer wont recognize it at...
The manual indicates that it should show charging as soon as connected, and takes three hours to charge.
I have found that on some devices, this does not happen, and it takes a few minutes for the device to get enough charge into the battery to start up. This especially from new, or if left for a long while.
Try giving it a long charge, six hours is recommended by some manufacturers, using the same type of battery.
leave your computer on, it won't hurt it, as the USB ports, only supply power when it's on.
If it does not work then, as you have only just bought it, take it back.
Feb 07, 2011 | Disney Mix Max Plus DS19025 Digital Media...
Mix max wont turn on even though its chargeing.
if u just put it in and it says its ok to remove don`t remove it kep it in for like 5 min. then take it off the charger
Jul 24, 2009 | Disney Mix Max Digital Media Player
How long does it charge i charged it for days but it still wont work at all so hpw long does it charge???????
Make sure that is turned on.(switch to the red side) Then once connected to USB port, it will start blinking red and green.Once fully charged the light will remain red. It takes about 2.5 hours to fully charge.
Aug 07, 2008 | Disney Tink Digital Mix Stick MP3 Player...
Zen m wont turn on
Well, it needs to charge via USB on your computer, so plug in your zen into the computer with the creative usb cord, and let it recharge. It may not necessarily turn on if it's really out of battery, but you can tell its charging when the switch you use to turn on and off, and hold, the light is blinking. After sometime, your Zen screen on the upper righthand corner should show a little battery and be blinking green what stage it's at in its charging. When its done charging the battery icon with be fully green, not blinking, and have a little plug icon inside of the battery icon to indicate that it is fully charged--takes a couple of hours to charge.
If that does not work, check your USB cord to make sure it's not damaged in any way. If it is, you may need to purchase a new one for better connection. And if that doesn't work, then you might need to replace the battery altogether, which I'm sure, if you are still in your manufactuer's warranty, they can do for you. After it is replaced, your zen should be good as new and ready to operate.
Hope this helps. Good luck!
Jul 17, 2008 | Creative Labs ZEN Vision:M Digital Media...
My iPod shuffle will not charge
If iPod shuffle won’t turn on or respond
â If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
â Turn iPod shuffle off, wait five seconds, and then turn it on again.
â You may need to restore iPod shuffle software. See “Updating and Restoring
iPod shuffle Software” on page 26.
Jun 25, 2008 | Apple iPod shuffle MP3 Player
When is the battery charged?
these small dvd player are built with less options
normally with cheap batteries, so usually it will turn green when fully charge or even turn off. hard to say. but since it cheap batteries, it probably wont do anything at all.
i would charge it for 10-14 hours then unplug the device.
the battery will get hot, and then the device will no longer work after over charging the player.
so charge for 10-14 hour only UNPLUG the player
play til it dies then start process all over again.
if you find that the battery is dying faster and faster then you have a cheap battery
theres no easy fix for this, some battery cannot be interchanged
when buying something make sure you can exchange the battery like a laptop. this way if the battery is overly charge it doesnt leak into the player.
or into the device
Jun 18, 2008 | GPX PDL805 Portable DVD Player
Disney Mix Max Digital Media Player Logo
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
