Question about Dishwashers
Zanussi DW907 Dishwasher stops early in cycle
Hi, my dishwasher starts up OK on the 65degC wash and fills with cold water. Then it starts washing as normal, but stops after about 2 minutes. It will sit there all day with just a barely audible hum coming from it and do nothing. If I click the timer around, it starts washing again. If I keep clicking it drains. I've checked the heater element (about 23 ohms) and that's fine. Can anybody give me a few pointers as to where to look next?
Many thanks.
  • 1 more comment
  • daftlad Mar 02, 2009
    ours does the same but then the element started to get realy hot could this be our thermostat at fault?
    ours started doing this but then the element gets red hot, could this be a thermostat problem?
  • skumspawn Mar 27, 2009
    Same issue, programme stops at various points, only manual intervention moves it on. The heater doesnt seem to work at all
    Sergeant:
  • 236 Answers
The heater relay may have gone on the pcb or you may have a stat/wiring fault in the heater circuit.
Posted on Feb 16, 2008
Zanussi 6015 dishwasher washes in cold water
the dishwasher might accept cold water but must heat the water up during the cycle. If it does not then check the heater circuit......element...thermos NTC, with a meter for electrical continuity....some dishwashers stop mid cycle if the re is no heat but some go right through on cold depending on the make.. good luck
Mar 01, 2011 | Dishwashers
DISHWASHER GE PDW7800J00BB DOES NOT WASH ,FILLS WITH WATER BUT NO WASH
It is unclear from your description if the wash pump starts and pushes the water around but never stops cycle or the dishwasher stops as soon as the water is filled.
If you do not hear the wash pump start then it is possible the wash motor is faulty. But if the wash pump starts and never completes the wash cycle then it is possible the heater is faulty and dishwasher is waiting for water to heat up before it can go to next cycle.
See the attached diagram for location of wash pump motor and heater.
Hope this helps you find the problem. Please rate the solution if you found it useful.
Oct 10, 2010 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher does not wash
If you are saying that in the wash cycle it fills and then stops it could be that your water temp is too low. Some models will stop to heat the water in the main wash before going into the agitate mode.
Apr 07, 2009 | Dishwashers
Hi there I have a Zanussi zdf121 dishwasher which is only doing a cold wash, not heating at all. Not sure if its hot fill but the hot water is fine elsewhere. Any ideas please Pete
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
Mar 02, 2009 | Zanussi 18 in. DA4342 Free-standing...
Zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
Jan 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Whirlpool dishwasher
hi there sounds like your wash pump may have burnt out can you hear the water trying to surge when in wash mode ?
Jan 11, 2008 | Zanussi ZT485 Built-in Dishwasher
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Dishwashers Logo
411 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
