Dead I have a RCA rear projection tv that is dead, I replaced the vertical IC with no change, checked for any opened, replaced 2 resistors and repaired some bad soldier joints, the unit is still dead. Model #P52921 or CTC195M
  • Henry Brue Feb 17, 2008
    I checked for the green resistors on the boards, I did not have any on this unit, and I could not download the manual for the unit no matter what I did. I am back the square one, I am getting my voltages, I will trase to check where it may be lost or stop.
    Henry
  • 552 Answers
Have you checked power going in toe the tv?
Have you checked all fuses?
There are fuses in the circuit board on some tv's that look like resistors, but have a green color and are shaped like resistors.
They are not marked, but there should identification on the circuit board next to each fuse.
Posted on Feb 15, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 24, 2008
    Try this link.
    It is for a service manual, but is not your exact model.
    http://www.eserviceinfo.com/downloadsm/2...
    Here is another link for you chassis.
    http://www.servicemanuals.net/results.as...
  • 2,336 Answers
Check this site for some useful info: http://wa6ati.com/CTC195-197.html
Hi, I have a Tedelex EC29187 Television it have only a horizontal line in the middle of the screen, I opened it and looked for physical damage around the vertical defflection IC, but it show nothing so...
Ur tv it is taken aparts wright now?Yes.Plug in ur tv to see the problems and take the hard end handle of the screw driver and taps around the vertical deflection ic for cold soldering joints,will require resoldering the ic,if the vertical hold flickers or bounced back to normal.No bounce back vertical hold check all the sorrouding capacitors transistors resistors for dead components parts to be replaced,if all the sorrouding parts are good,than that vertical deflection ic it self it is dead and require replacing.
May 09, 2011 | Televison & Video
Horizontal and vertical lines themselves are off skew. can you adjust these convergence ines. everything else color ok
No,this tv 100% have convergence problems,it dead.Any colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | Mitsubishi WS48511 48" Rear Projection...
I have samsung hcn473 tv. The screeen is covered with squiggly vertical lines. Even watching a dvd movie, its the same.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board is dead,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | Samsung HCN473W 47" Rear Projection...
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
I have a RCA Rear projection TV and the picture on it looks like a bow tie
This problems u have is known as Convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-$350 for parts and labors.
Aug 16, 2010 | RCA P52929 52" Rear Projection Television
Red convergence looks like its curling in the coner like on either end it bows up ~------~
The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 23, 2010 | RCA HD52W56 52" Rear Projection HDTV
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Multi- color bands - twisting wave pattern cross the middle of screen and can not get image to lock -flickers both horizonal andf vertical. Would this be the same 2 IC chips- last time i had this problem...
Ur tv have convergence problems,it dead.U must have soldering tools,solders and know how to solders to fix convergence problems.U must replaced 2 STk convergence ICS,and some or all it resistors.Tries websites Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300-$350 for parts and labors.
May 11, 2010 | Toshiba 50H72 50" Rear Projection...
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
Horizontal lines then picture starts to fade
The horizontal/vertical ic inverter is dead.
Needa new one.
Aug 02, 2009 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
