Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Change the water filter
I have an Amana AFD2535DES Refrigerator and want to know if I need to shutoff the water supply to change the water filter. I think the filter number is #UKF8001Axx. It pulls down from the top of the fridge
    Scholar:
  • 90 Answers
Most are ok to pull as there is a shutoff in combination with feed lines... If in doubt and the water shutoff is convienient to get to turn it off. Otherwise just pull the filter...especially if it simply snaps into place as it should take care of turning off the water as the filter comes out....
Posted on Feb 15, 2008
Water dispenser on inside door doesn't shut off. I have turned the water supply off but want to fix it.
The water inlet valve on the back where the water supply comes in may be stuck open and need replacing.
Jan 01, 2011 | Amana AFD2535DES French Door Refrigerator
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Amana refrigerator # AFD2535DES
needs cleaned..underneith..use your vacuum..take off kick plate.in front..go to Amana website they have answer section...
Aug 28, 2009 | Amana AFD2535DES French Door Refrigerator
Water dispenser inside my maytag MFD2561 refrigerator is not working. what could be causing this problem and how do i fix it?
check water supply
check water valve
check filter
check for frozen water tamk
if none of those are bad check the switch at the control,
Jul 14, 2009 | Amana AFD2535DES French Door Refrigerator
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
82 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
