Sharp VCR Model VC-685U
Tape will not eject,rewind, FF, Play...have reviewed all troubleshooting items in manual and it still does not respond.
When powered up it goes on -hit play and in a few seconds shut down...believe there may be a short...
Please advise & Thanks for your attention.
Jay
  • jaybird44 Feb 15, 2008
    Turns out to be broken plastic on left side of cassette. Now working well. Thanks for your assistance.
  • keenspotter Sep 12, 2008
    I have the same problem - the tape will not eject, play, rewind, etc. The tape contains scientific data, so I don't care about getting the device to work, all I need is to get the cassette out.
Sony DSR-45 getting error C3211: Tape will not eject ,play ,ff or rewind . How can I get tape out of machine:
Posted on Nov 21, 2008
  • 979 Answers
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
Posted on Feb 15, 2008
How can I get my tape to eject?Sharp VC-A560. Played my taped, rewound, but tape would not eject. Tried to play again and it would not play.What can I do?
Unplug from wall outlet - find the wheel that ejects the tape when you slowly turn it. It's usually on the right side when the cover is open. Avoid touching any metal parts.
Mar 01, 2015 | Sharp VC-A560U VHS VCR
Why does my Sharp VCR pops out all my tapes without playing?
Check the tape tension ... rewind and rere-rewind and try that.
Aug 05, 2014 | Sharp Televison & Video
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
Close when play vcr
Problem in the mechanism that moves the tape in play,ff,rewind and also winds tape back into cassette and ejects it.
Likely a bad or worn belt or drive idler(rubber).
Nov 04, 2012 | Televison & Video
The VCR doesn't eject the tape
need codes for vc-aa350 is locked
Sep 01, 2009 | Sharp VC-A560U VHS VCR
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
Symphonic sc1304, vcr problem
Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
Jun 04, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Televison & Video Logo
299 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
