Bush TV Dead MODEL: 5693D
I have replaced a burnt out Zener-Protected MOSFET Ref Q102, it will not start up.
Have checked most pwer supply components, LOPT etc but cannot pin point the problem
    Problem Solver:
  • 6 Answers
Switch mode power supply? it has a in or primary side and out the secondary side of a switch mode transformer.
check the driver IC that runs Q102 it makes a oscillation that Q102 amplifies. now the secondary if has a short will blow the Q102 look for shorted rectifiers in the secondary and fuse resistors that are open, even go far downstream and check the HOT for short.
Posted on Feb 23, 2008
My bush 24inch TV has no power. It was fine, but now has no power light on. I have changed the fuse and checked it in a different socket. What could be the problem?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
Jul 20, 2014 | Bush 5693D 24" TV
42"flat screen not getting power,goes on for a while and then goes off
Usually means power supply problems. Unplug and check inside set near on/off button where power comes in, look for burnt or damaged components.
Nov 19, 2013 | Bush 5693D 24" TV
My bush lcd32tv022hd will not turn on! No power! Any theories??
First check fuse in pwer board, if it is not burnt then check the main capacitor must pop up, replace the poped component and your tv works fine again. Thanks
Feb 25, 2012 | Televison & Video
I have a sansui tv set with a power problem . MOSFET W11NB80 in the power section is completly blown . can t get it in the local market in kenya what is the equivalent value. its a crt television...
Hello
W11NB80 is an N-channel 800V-0.65ohm - 11A - rated Metal Oxide Semiconductor Field Effect Transistor [MOSFET]. You can use the folowing substitutions for it
[ 11NM-80, 12NK-80 & 10NC-802]. All of these are its equalent substitutions.
Before replacing the mosfet, check the entire power supply secion for any short circuit, or zener diodes faults. If any of the zener diodes are fused, it will run out the MOSET you sumstitue again. Check it keenly. Unsolder one end of each component, lifit it up a liile from the circuit board and check. Especially zener diodes must not show any leak in 100Kohms range. It is best to replace them all I suggests.
I don't know about its availability in Keniya, yet you try to get it from any electronic spare part shops. f feels any difficulty in getting the same contact [E-Bay] site, they will reach you the exact component at your doorstep. Ok.
Dec 28, 2010 | Sansui DTV2760 27" TV
A ups mosfet ckt one mosfet burnt out og 16 can i replace only one
Usually the mating one has been degraded or damaged as well. Replace as a pair, or all of them that are in the same function.
OFTEN driver transistors and drive diodes are also damaged. Carefully check all associated components to avoid burning out freshly replaced ones.
Mar 14, 2010 | Vector VEC 024 400-Watt Power Inverter...
Bush lcd27tv006hd no power ,no stndby lights
Open the back cover of the monitor.. check the fuse at the power supply board... If the fuse is open, replace with same value.. at the power supply board check for any blown capacitor and replace it with same value. Check also the power cord for open connection.
Feb 04, 2010 | Bush 5693D 24" TV
Bush lcd tv..no power
The power supply has the problem
Oct 26, 2009 | Bush 5693D 24" TV
Mosfet in my asus motherboard burnt out,
Better to have the motherboard replace, do not wait until some other components might be also damage. Commonly mosfet is use in power supplies regulator. It can kill your processor and memory.
And also check your power supply. It might also having problems.
May 02, 2009 | ASUS P4GE-MX Motherboard
Had power outage while tv was on. When power restored I turned on tv with remote. TV sounded like it went on but no picture. Only timer light lashing. Sony Wega older model 27" Please help, thanks
next time dont leave your tv pluged on power, the power supply got burnt, check your power supply on the following components
fuse, power transistor, zener diodes,also rectifier diodes
if you can manage do it at home
or take it to a w/shop
Apr 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Bush TV Model No 5693D
Try using the source button to switch through different inputs.
If that does not work try connecting a signal booster to the aerial, they cost about ten pounds at Argos.
Mar 06, 2009 | Bush 5693D 24" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
