Red liquid Large amount of a red liquid and water leaked from the washer.
  • schamrelb Oct 04, 2008
    Hi I have a 16810 that started spilling brown liquid and dispalying code E 10? What does it mean?
    Sergeant:
  • 236 Answers
Red liquid is rusty water, check from where possibly a water pum or from the tub running down onto a metal component.
Posted on Feb 16, 2008
Leaking water after stopping
Liquids in an auto..... Antifreeze (greenish/clear, watery, with slight oil feel to it, smells somewhat sweet), Power Steering Fluid (very thin oil, usually red tinted), Brake Fluid (very thin oil, clear), Transmission Fluid (very thin, red and kinda of sweet smelling), Motor Oil (amber colored or black, medium viscosity, usually smells acidic), Washer Fluid (usually water). Only other fluid is condensation that drains from the air conditioning drain pan after driving the car and the air conditioner has been on.
It can only be one of the above, really need a lot more information, to even begin to make a guess.
Dec 17, 2012 | 2001 Buick LeSabre
Clear liquid is leaking from the bottom of my 2009 sentra
There is little I can think of that is going to be a clear liquid in your car. The only things that I can think of 1. Condensation coming from the drain of your A/C unit(most likely), 2. If it is a small amount and it is coming out of the tail pipe, it is water. The catalytic converter turns most of the unburned gas from your engine into water.
Automatic transmission fluid is RED, Antifreeze is Green in Nissan products, Brake fluid will be a semi clear liquid with a brownish hue to it. Manual transmissions use gear oil which is a golden color. Engine oil, depending on how well the car has been maintained, will be a light goldish to a black.
I hope I have answered your question.
Aug 06, 2011 | 2002 Nissan Sentra
What is the small plastic container in the engine compartment on the driver side used for?. What liquid is used to fill it?
It could be either engine coolant or windscreen washer water. If it has green or red water in it it will be the coolant. If it is clear it will be washer water . It could also be the power steering resivoir which will have red to brown light oil in it. This is topped up to the full line when the car is hot.
Mar 04, 2011 | 1995 Toyota Camry
Leaking from some where-hoses are dry
the way we fix this is put a small amount of water color / red /blue into the bowl take the back of and watch as it washes to see were the leak is
Dec 29, 2010 | Frigidaire GLWS1339AS Top-Load Washer
Maytag top loader slight leak from bottom left corner
Thank you for responding. Yes we fixed the problem. After taking off the front cover noticed the hose from the liquid bleach dispenser (which I never use) was not connected. Evidently when using the extra large load a little water would splash into the bleach dispenser, hence the small amount at bottom front left corner where dispenser is located. So simple! Glad I didn't pay for someone to attach the hose. Thanks again for your timely response. Lynn
Mar 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sometimes,water leaks out from under washer. the amount is cleanable with two large bath towles. Machine is just out of warrantee. Please advise
I suggest that you check the screw holding pump motor to pump, if they get loose water will leak
or check the short hoses from pump, clamps may abe loose
Jan 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
FRIGIDAIRE DISHWASHER FDB1050REC0 LEAKS UNDERNEATH
There are a couple reasons water may be leaking out the door of a dishwasher.
1. The water is most likely coming out the bottom of the door where there is no rubber seal.
2. The rubber seal is around the door jam on top and both sides and not on the bottom. This means if the dishwasher has to much detergent in it the soap suds push only the water higher than the front edge of the wash basin and out the bottom of the door where there is no seal!
3. Fill only the soap cup that can close for the secondary wash. The open cup is a pre-wash and mostly not needed unless the food is baked on.This just wastes money to fill both of them every time.
4. And if you are using liquid detergent you only need half the amount from the powdered soap!
try less soap. Remember to much soap too can cause the water overflow.
5. And the last would be that the drain is clogged and caused a back up large or small and then the overflow!
is there water in the bottom when the wash is done?
Soap is usually the culprit, not that there can't be a leak in an old drain or water supply hose!
Go with the soap idea first!
Let me know how you are!
How old is the washer ?
Please remember to leave a rating before you go!
Thank You ,Huuum
Sep 27, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
