Question about Panasonic PT-47WX49 47" Rear Projection Television
Beeps when turned on then power light blinks 5 times
I had a boxelder bug die on my screen when I took the back off of tv it worked fine. After cleaning the dead bug off the tv won't come back on.When I try to turn it on it beeps for about 5 seconds and then the power light flashes 5 times pauses and flashes 5 times again keeps repeating this.
  • Panasonic Master
  • 5,138 Answers
CHK hori output transistor and STK392-110s (2) of them. hori output NTE2973.If you know what these parts are then you can fix it yourself if not carry to repair shop! ThankYou for trying FixYa. Have a Nice day.
Posted on Feb 18, 2008
  • 126 Answers
Sound like the b+ line is not getting the voltage call a tv repair tech.
Posted on Feb 17, 2008
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
My Sony tv screen blinks off and on and timer/standby blinks 5
Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
Feb 26, 2010 | Sony KP-53HS10 TV
REAR PROJECTION HDTV ISSUE
Decoding the number of beeps may be possible with the owner's guide but this type of problem is normally due to a failed power supply.
These are often mounted on separate boards located in the bottom of your set and can be identified by the much larger parts you see on the board and possibly its relationship to the AC cord coming in. While these can be repaired, the cost of that will approach the cost of a new assembly.
Unfortunately, modern, more energy-efficient power supplies have some critical components that if bought cheap, don't last very long and frankly, 5 years isn't bad, I read of many dead within the first year.
Jul 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
TV blinked out and now it doesnt come on?
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Feb 26, 2009 | Akai LCT2715 27 in. LCD Television
RED LIGHT IS ON BUT IT WILL ON TURN ON(GREEN)
Feb 18, 2009 | Akai LCT2715 27 in. LCD Television
Olevia 540-B11 - no power
Jan 03, 2009 | Televison & Video
Philips flat screen tv will not power up.
Dec 20, 2008 | Philips 32PFL3403D/27 32 in. LCD TV
I have a 53 inch wide screen Panasonic that is roughly 5 years old. It was working fine until I now hit the power button and the light stays on and then the picture comes on for 5 seconds then the TV...
whatsthe model number of your panasonic. Most panasonics mean convergence failure when the led blinks 3 times. Please respond to this post with your model number and I will post the correct ICs for your model and where you can get replacements with free instalation instructions
Jun 27, 2008 | Televison & Video
NO PICTURE
it is you senser that when you take the back end of your cover off there is a little chip there just tape it lol
Apr 18, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Six beeps of the standby light...
Yes your suggestion is correct. This type of problem occurs due to humidity also. Solution is if your a technical person or service person just remove main pcb from the tv and blow all dust and clean it. Check whether the dry soldered in power supply area and jungle ic area. if found clear it. Now the tv is working well and good. 6 times blinking means problem in jungle ic area.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
105 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
