Question about Brother IntelliFAX 2800 Laser Fax
HELP WITH THE MACHINE
THE MACHINE WILL NOT PRINT THE RECIEVED FAXES HOW DO YOU FIX THE PROBLEM?
  • NIKKI44 Feb 15, 2008
    IS IT POSSABLE THAT THE CATRIDGE YOU PUT THE INK TONER IN CAN BE REPLACD?
  • 123 Answers
Hello, have you tried to replace the toner cartridge, if the page is plain with no markings you could also have a defective "Imaging Drum"
Posted on Feb 15, 2008
  • Steve Martyn
    Steve Martyn Feb 15, 2008
    Hi Nikki, Its a Laser based unit so you might need to buy a new toner cartride (assuming it is the Toner), Laser works differtly then a standard home inkjet. How busy is your fax machine, and did you notice the print fading before it went? Do you have any warning lights on the front of it?
How do i retreive and receive faxes? My machine has recieved material in memory, yet when i try to print them, the alarm rings after first page and display reads "CHECK PAGE SIZE, press OK" It will re
If you are able to print normally from this model, despite the 'stuck' faxes, then it could be that you have been sent a document that is not the same size as that in your tray. Try cutting A4, if that is what you have, down to 'legal' and see if will move on to next page. If this works, cut some more and print job till finished.
If the above makes no difference, you may have to do a memory reset to clear a corrupt fax record. Caution! this would clear all faxes queued in your machine.
Dec 16, 2014 | Canon PIXMA MX340 Inkjet Multifunction...
I received several important faxes that did not print, just blank paper. Then I realized I was out of ink. Anyway to retreve those lost faxes?
Not normally...once the machine "thinks" it has printed the information the actual Data is no longer kept in memory...there may be a record of the fax being recieved but not the actual Data.
Feb 13, 2011 | HP 1040 Plain Paper Inkjet Fax
My canon jx210p fax receives all faxes into memory. how do i stop this and get it to print all recieved faxes straight away?
Hey!
If u briefly press the on/off button it will say auto print on and will print the faxes as soon as it comes in!
Good Luck!
Jan 12, 2011 | Office Equipment & Supplies
I have an old cannon fax machine from 1988. It has been blinking "recieved in mailbox" and I can't figure out how to clear it. the model is canon fax-705. can anyone help?
It has messages or faxes in memory, and is waiting for the right conditions to print.
You may need to add paper, replace the toner cartridge, or clear a paper jam so that the printer can work.
Mar 22, 2010 | Office Equipment & Supplies
CAN THE MEMORY BE LEAGNTHED ON HP1020 TO HOLD IN MEMORY MORE FOR INCOMING FAXES OR ELIMATE HOLDING RECEIVE FAXES AND PRINT PAGES AS THEY ARE RECIEVED INSTEAD.
I found the manuel on line and found out how to print the faxes in memory to release the memory. So next time a big fax comes thru I will try to print and release faxes from memory.
Nov 13, 2009 | HP 1020 Plain Paper Thermal transfer Fax
All of a sudden, faxes stop coming out and the window says something to the effect...''Place US Paper in Upper Tray''. If I turn the machine on and off, the display clears and faxes that are in memory...
The fax machine is trying to print fax recieved copies on the bypass feeder.
Check up the setup menu on the control console.
Fine fax recieve.
You should find a selection for fax recieved in which paper tray.
Check this area, any that have the bypass feeder, de-select it.
Make selections for 8 1/2 x 11 paper in tray one.
May 01, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Faxes will not print.
check for the location of the faxes, and how they are being saved, in the preferences menu.
Dec 12, 2007 | Lexmark X9350 All-In-One InkJet Printer
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Brother Intellifax 1270e
Make sure ribbon is installed correctly. Also check inside the tray area to see if the rubber roller and or the rubber separator pad is dislodged. Obviously not worth repairing unless under warranty.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jul 09, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 2800 Laser Fax Logo
27 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
