Question about Sub-Zero 632 / S
Clean coils and service message
When the clean coils message came on, we removed the top grid and vaccuumed the coils and cleaned the grid. We replaced it and screwed it back into place. We have done this before successfully. This time after we did this, the vacuum coils AND the service message comes on. Any idea what we need to do?
Thanks!
Joellen
  • jellin Feb 15, 2008
    We have cleaned the coils before successfully. I.E., the vacuum coils message went away when we put it back together. I don't THINK there is anything that needs to be done underneath the unit. Compressor and fan run on top. We also tried turning it off and back on. I don't know if there is a re-set button or not, but we didn't need it last time. Should probably take a look at the owners manual. It costs $119 for someone to come out and do what we did, so obviously we are going to try to find our own answer first. Thanks!
    Scholar:
  • 90 Answers
Not familiar with your unit, but, are there coils under the unit? Where is the compressor and is there a fan running, moving air under the unit? There may be a sensor at either place that needs wiped off or is covered with dust so as not to be able to sense air movement. Let me know and I will try to help you further....
Posted on Feb 15, 2008
  • Timothy Smith Feb 16, 2008
    OK. Since the compressor is on top, there must be or at least I am making a guess that there is a sensor up there that senses air movement or picks up a signal from an emitter of sorts. It would probably be in a tube or small round holder at both transmitter/emitter and receiver. They would situated such that if enough lint or dust accumulates on the coils it would inhibit that light, probably infrared, to not get from one point to the other. It may be that you have the coils clean but a bit of dust is still covering one or the other. Not knowing this unit, I am kind of lost in helping other than knowing how other similar sensing systems work...The number listed for help line is 888-222-7820. All I know is if it is sensing that the coils need cleaned there has to be a sensor to tell that. Make sure all of the fins are straight and unbent as straight from the factory. Use compressed air if available to blow out all dust. This is the best way as it does not come in contact and bend even very light duty metals....
How to remove front cover to clean evaporator coil on gibson gah12er2t
pull the unit forward almost taking it out of the wall, on top and to the sides or under there should be some screws to take off the plastic grid. before you do that please make sure there is no power to the unit.
Aug 12, 2011 | Gibson GAH12ER2T Thru-Wall/Window Air...
Tip
FRIDGE NOT COOLING THAT GOOD
AT THE BOTTOM FRONT OF THE FRIDGE, UNDER DOOR, REMOVE VENT COVER. JUST SNAPS IN PLACE. USE A SHOP VAC OR VACCUUM CLEANER WITH A SMAL ENOUGH HOSE TO INSERT THROUGH THE BOTTOM OF FRIDGE. CLEAN COIL AS GOOD AS POSSIBLE FROM ALL DUST AND DEBRIS. DO NOT USE ANYTHING POINTED OR SHARP BECAUSE COIL CAN BE PUNCTURED OR DAMAGED. ONCE COIL IS CLEANED YOUR FRIDGE WILL START GETTING COLD AGAIN!!!!
on Jan 09, 2010 | Refrigerators
My Maytag portable A/C will blow cold air for one cycle, then after about five minutes it just blows room temp air and never gets cold again. If I turn power off then back on it does the same thing over...
Cleaned the filter screen or the coils? There are two coils. The evaporator coil and the condensor. There is the "filter screen" in which you can clean which is located in the back top portion of the panel that is easily accessible. However to clean the coils you need to remove ALL the back screws from the back cover and remove the entire back panel. There you will see both coils. From your statement it sounds like there isn't sufficient airflow over your coils and the freon cannot release its cooling effect into the hot air thus it tends to ice up on the coils. You need to wash out all the lint dust from both coils. You can do this with with air conditioning coil cleaner or for starters use a stiff paint brush and vaccuum. Clean as much debris off as you can, then run the unit. It should last longer than your previous five minutes. If it doesn't work then your in trouble. There is a metering device called a TXV or expansion valve that may have failed causing the freon not to flow freely thoughout your system. However it is a rare occassion that it fails so it should be that the coils are dirty. GOOD LUCK
Aug 25, 2010 | Maytag NMPEB08F2A Air Conditioner
Does this D.E. filter have to be cleaned 2x a year?
You need to break down and clean this filter one time each year but twice wont hurt at all.
First get a five gallon bucket for garbage. Then mark the shell of the filter and the band clamp so you can line them up later. Use a magic marker for this.
Now undo the clamp on the tank and remove. then open the air bleed to drain the tank. If you can't remove the top turn the pump on for a second or two to pop the top.
Remove build up of DE on the top of the grid assembly and discard. You will find two bolts comeing up through the plastic manifold. Remove these and clean. Now grip the manifold and with a rocking motion back and forth gently pull up. When this comes free clean and set aside. Gently seperate the grids and remove DE packed between them and discard. Remove grids and lower rack and hose off.
With the valve in BW position hose down the inside the tank. Inspect the "O" rings and replace as nessary.
Now take the manifold and turn up side down on the bucket. Take the grids and insert into the holes in the manifold being sure the small grid is in line with the space for the stand pipe. Now replace the lower rack and gently work into place. DO NOT FORCE THIS.
Tip to one side while holding together and start nuts on through bolts. Rite up the assembly and tighten these nuts.
Grease the stand pipe "O" ring and set the assembly back in place.
Replace the top and clamp lineing up the marks you made when starting. Evenly tighten the clamp.
Reset BW valve to filter and recharge.
You may want to hire someone to do this the first time and watch them before trying to do it yourself. Good luck.
Apr 10, 2010 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
Freezer won't freeze
remove rear panel in freezer and see if ice an frost is there. if so defrost heater is kaput or the contollers for it.
May 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My amana model #SXDE27NE says i need to clean the coi. How do i do this?
remove the lower kickplate, and youll find the "coils" under there, with a refrigeration coil brush youll be able to vaccuum all the dust out from there
Feb 21, 2009 | Amana Refrigerators
We have a CLR2060. It makes ice fine for several days, then the grid freezes over. We have cleaned it recently.
What did you use to clean the grid? It must be U-line cleaner. I seen people use other cleaners just to find the same results. If the ice isnt ejecting then you can check the hotgas coil. It should be 360 ohms. If its open or week I see this from time to time. If its neither then you need a service tech to repair the sealed system . Replace the hotgas valve.
Jan 10, 2009 | U-Line Icemaker
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Sub-Zero 632 / S Logo
96 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal De GO PATS
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
