Question about Edirol UA-4FX External Sound System
Can't Get To Advanced Options
I can not get to BIOS from Advance Options. During startup my Tecra 9100 will not go to Advance options. I press down the Delete key, the Tab key, the F keys. Please tell me how to get to Advance Options. When WINXP Pro updated to SP2 I lost all sound and under Device manager the sound card is not listed. I went to Toshiba Support and I tried to install the Yamaha Sound Driver and it goes through everything and at the end it says NOT INSTALLED. Pleae help me.
  • 88 Answers
XP updating to SP1 seems a little odd in february of 2008, why not SP2?
To get into your BIOS you need to hold down escape key as you turn your laptop on and keep it held down until it reports an error, then press F1 to check BIOS. You can actually alter BIOS from within the OS environment with Toshiba laptops through a utility called HWSetup and I suspect that's where your problem lies.
Make sure your audio device is enabled in BIOS and if you need to re-install HWSetup you can find it here:
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=442210xml&sliceId=&dialogID=30704477&stateId=1%200%2030700832
Hope this helps,
erch.
Posted on Mar 14, 2008
Add boot option and change boot to usb
You need to change boot options in BIOS. Press required F key during boot. Look on the screen since Function keys vary with systems. In boot options make USB 1st. Save and reboot.
Note: Some systems have an boot option during startup. Thus eliminating the need for BIOS change. Again, look on the screen for F key.
Oct 28, 2012 | ASUS U46ERAL5 Notebook
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
I cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
In bios how do you access settings in intelligent tweaker
To access the BIOS Setup program, press the <Delete> key during the POST when the power is turned
on. To see more advanced BIOS Setup menu options, you can press <Ctrl> + <F1> in the main menu
of the BIOS Setup program.
Once in the MIT menu CTRL+F1 should show you more advanced options also.
Mar 22, 2012 | Gigabyte GA-G31M-ES2L Motherboard
CANT FIND HARD DRIVE DURING INSTALATION
Put the hard-drive in another PC and see if it works .....
And if it do then.....
the pc that showed the error could have a problem in the bios setting (press F2 to get the bios during boot to get to the bios setting....try to reset the bios setting to factory settings)....or you could have to perform a flash of the bios.....
Apr 05, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
Password shows on start up i think it's a bios password
To reset the BIOS read the information from this link to see your options: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
In case of your laptop the easiest method would be using Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Feb 16, 2011 | Toshiba Tecra 9100 Notebook
During the start up a blue screen will pop up for an instant then the computer shuts down. I cannot start the computer any longer. Is there a way around this issue?
You want to disable "Automatic Reboot" on system failure. This option can be found in "Control Panel"-->"System"-->"Advanced System Settings"-->"Startup & Recovery" "Settings" button.
This will let you see the Blue Screen error and find the file that is causing you problems. When you find the file, Google it and read up. You should be able to find easy fixes to it.
But to get into Windows you will need to boot into "Safe Mode". You do this by pressing F8 repetitively after the BIOS screens...when Windows is loading. If you hit F8 at the correct time, you will be greeted with a black screen with white lettering and a few options.
While you are at it, do a virus/malware scan using the free program at http://www.malwarebytes.org
Hope this helps.
Jul 13, 2010 | Toshiba Tecra M2-S630 Notebook
No hard disk found
From what you describe, your 40GB should be compatible with Tecra 9100.
I'd suggest you reset the BIOS settings to the factory defaults, just to ensure there are no wierd settings. Have you managed to use any other HDD with your Tecra 9100 previously?
Have You checked for a BIOS update for this model / vintage ?
Oct 14, 2009 | Toshiba Tecra 9100 Laptops
Toshiba tecra 9100 video output
Try reinstalling the video driver, make sure you have the latest correct version (ie. XP or Vista).
You might need to download the video driver from the Toshiba WEB site, and make sure you select the correct model laptop.
Jun 20, 2009 | Toshiba Tecra 9100 Notebook
My Toshiba Tecra 9100 won't go into STANDBY MODE
You have to use the Toshiba Power Options in the control panel
Mar 11, 2009 | Toshiba Tecra 9100 Notebook
Edirol UA-4FX External Sound System Logo
85 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
