Question about Nikon D70 Digital Camera with 18-70mm Lens
Nikon d70 flash stopped working
I was using the camera and it was working just fine and then the builtin flash stopped working. When I tried to use an external flash it wouldn't work either. HELP!!!!!
  • 1 more comment
  • Rollee Feb 15, 2008
    Yes I am getting images. The camera works fine without the flash but I need the flash to work as well. Could this be a wrong setting? I have tried everything. I was in the middle of shooting a wedding when it stopped working.
    Thanks for your help. I had a feeling this was going to be "not good". I have someone here who is going to take a look at it and repair it. Thanks so much again for your help.
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    This sounds like a shutter problem. Are you getting any images at all?
  • 667 Answers
Well, you are not going to like my answer. The troubleshooting guide for the D70 says it could be 1 of several PCBs (printed circuit board) being faulty or the connecting FPCs (flexible printed circuit).
You'll need to locate a local repair person or use the reapir service search here on Fixya. Nikon USA repairs will be $$$$
Posted on Feb 15, 2008
Is this flash to use on a nikon D70 camera. It works on a F70 but on a d70 its not functioning
The Achiever Flash 630AF is for Film Cameras and will not work properly on the Digital D70 camera.
Nov 29, 2010 | Achiever 630AF for Nikon TTL Flash
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Nov 02, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
Mar 09, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
Promaster 7500 D Digital Flash usage with Nikon D70
you need to go to your cameras menu and set your flash function to m ( no to ttl) set it in full M and then it works hope it works that works for me i had the same problem
Dec 05, 2008 | Promaster 7500DX for Nikon TTL Flash
CAMERA WILL NOT SWITCH ON NIKON D70S
http://nikonsro.com/email_images/nikonusa/service_advisory/d70.html
Is this your problem? If so, Nikon will repair it for free, even if it's out of warantee. :)
P.S. Please stop "shouting!" (Turn off caps lock!)
May 31, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D70 flah not working, used to
I had this problem a while back, but was fortunate to get it fixed under warantee as it was less than six months after Nikon repaired my D70 for the "blinking green light of death" fault.
I'm afraid this is a repair job for Nikon or an autorized workshop. It is most likley the flash tube. If you fancy taking your camera apart (I warn you it would be a fairly difficult job) then please be aware that you may get a significant electric shock from the flash capacitor, which will remain charged.
Feb 18, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Random pictures
Check in the user guid for your camera about their recomended shutter speed setting for the flash.
Try using the camera and the flash in "A" (automatic) to start with.
Jerry G.
Feb 15, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
Nikon D70 Digital Camera with 18-70mm Lens Logo
221 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
