Question about Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard
Display Screen goes black
My Compaq Laptop Display Screen starts flickering and then goes black
  • ongksee Aug 20, 2008
    Display is very faint and dark.
    Master:
  • 474 Answers
If its flickering and turning off, do what the first guy said as its probably the power save settings kicking in to conserve batt. power.
If its making weird colors up and down and going out. It may be a bad video card or screen in which you would have to have it repaired
Posted on Feb 18, 2008
    Scholar:
  • 160 Answers
Right Click on Desktop
select Properties
select the Scree Saver tab
Click on the Power Button which is on the right side
select the power schemes
In that select the power schemes options and choose "Never" for turn off monitor, turn off hard disk and system stand by
click on
Apply
Repeat the above step for each option in "Power Schemes"
then click on ok
Posted on Feb 16, 2008
I have an HP/Compaq nc6220 laptop. When I try to boot it up it flickers the goes to black screen and won't boot up. What should I do?
If you havent tried to boot your operating system from a disk or jump drive (which you can get from you local PC store for around 5 bucks) then I'd say your either missing harware components, or the ones you have are fried, and your better off buying a new PC.
Sep 25, 2012 | HP Compaq nc6220 Notebook
My LCD screen has been flickering.
Sound like the display panel needs to be replaced
Aug 16, 2012 | Compaq Presario CQ62-215DX Laptop
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
How to solve laptop nx7300 screen flickering
sir try un-installed your video card then install angain.
Feb 22, 2010 | HP Compaq nx7300 Notebook
Presario R3000 display went dark can not see Screen goes black after a few minutes of use. You can see a very faint image after a few seconds, but you must do a soft re-start to bring the screen back....
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 01, 2009 | Compaq Presario R3000 Notebook
Screen is blinking very frequently
Hello, this is a known problem with the model of that laptop. You will also notice in safe mode your screen will not flicker but in normal mode it will flicker.
Your laptop should still be under warranty and needs the LCD replaced.
Mar 04, 2009 | HP Compaq 6720s Notebook
Lcd hdtv is hooked up to laptop but it is every 10 sec gos black
if theres nothing happening on ur pc like same as tv its probably the tv config ...
check tv setup
check tv screen saver..if it disabled it would explain why screen black...
could try checking power settings in pc(screensaver properties)
Dec 10, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario 1700 Laptop screen flickers and locks up
it sounds possibly that it is going into hibernation. a single press of the power button should bring it back alive.
also feel the bottom of the laptop.... if it is getting close to meltdown you need to clean the dust and dirt from the heatsinks. the fan area may appear to be clear but all the junk gets blown against copper heat sinks so you need to remove the covers to get at it.
Robert
Sep 05, 2008 | Computers & Internet
Lc display
how many hours do you have on that monitor could be lamps or just fusses
Nov 20, 2007 | Compaq Presario 900 /1500 Series EVO...
Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard Logo
123 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
