1994 Mercury Tracer Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Tracer has about 44k on it. When sitting at a stop light, idling, the car seems to run rough. Is a tune-up the place to start? The car was previously owned by an elderly lady (no kidding) so I'm not sure what she did as far as regular maintenance.
Anonymous
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Jan 25, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
58
Questions
Helped
15971
Points
179
I would start with changing the oil and oil filter,air filter and also change the plugs and wires. That will smooth it out alot.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Mar 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
3360
Points
14
You might also look at the mass airflow sensor
2answers
Rough idle while in gear. There are no engine lights on. I replaced the spark plugs 6 months ago and seemed run better. Rough idle came back, so I cleaned out the PCV valve and it helped for the short...
Are your rpm's low when sitting at a stop light and vehicle warmed up? You could check your TPS (Throttle position sensor) or maybe your egr is plugging up, or one of your plugs or wires could have gone bad, maybe the coil on one of the wires is bad. You really need to plug a code reader into the ECU and see if there is a code being thrown. And NO, all codes will not cause the engine light to come on.
My 2007 Chevy Silverado loses power when I come to a complete stop no engine lights appear but if I turn off the truck the problem goes away for awhile .
Loss of power, but no mention of rough or inability to idle (including stalling). If those additional symptoms are part of the problem, check for a vacuum leak to the intake. Listen for hissing or sucking noises near air hoses. Look for loose, cracked, or broken air hose connections. Check PCV valve...Cheap to replace, could be sticking, then loosen after truck sitting with engine off. A vacuum leak will not give any light indications, and vehicle will seem to run normal when applying gas, but will want to stall or run rough (or want to stall) when at idle or sometimes when taking foot off gas when slowing down.
Idle good when cold, hotter it gets the worst it idles especially when sitting at stop lights
simple test for a vacuum brake booster
star and run the engine at idle without applying the foot brake
if it gets worse when the foot brake is applied , it is a vacuum leak in the booster ( replace the booster )
otherwise check for failed vacuum hoses including under dash control lines , vacuum leak at the manifold or EGR unit
3helpful
Ford E-350 2001 V-10 gas. 70k mi. - problem developed suddenly, no gradual lead up. - runs rough, stalls both driving or sitting idle, seems to surge a little i.e. surges above idle rpm while sitting. was...
Check your fuel vapor recovery system, your van has unusual set up, and the effect is RAW fuel gets purged, rather than vapor.
The dead giveaway test is does the issue happen on light acceleration? Does it stop if you let off the throttle? Can you accelerate harder and "get past" the issue?
1helpful
Rough idle then stalls
Vacume leak or bad idle motor. With the car in park and running with the hood open listen for leaks moving your hand around the different hoses looking for a change in the sounds that you hear. The idel motor also makes the car idel up to 1500 RPM or so right at start-up then idel down, If it doesn;t the idel motor is likly. Check engine light is on when running? Test for codes, Follow code test charts don't skip any steps!.
1helpful
Rough low idle in gear when stopped at a light.
probable vacuum leak query brake booster
2helpful
Fuel Pump Problem?
lots of stuff in the fuel system can couse problem like pressure regulator, pressure switch,or relays. pump could be on way out though.
3helpful
2answers
2002 Kia Rio runs rough when idling
well spend some change and have a simple tune-up.  Plugs and filters and readjust the idle.
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
