Wharfedale tv I've just bought a 37" Lcd model L37TA6A and the screen size keeps defaulting to 4.3 giving me a small sqaure picture. I can zoom in and get a full picture but it doesn't stay that size for long and changes back when i change sky channels. Is it faulty? thanks
  • Bex36 Feb 16, 2008
    Thanks but already done this. Sky have sent a boost to my box but same problem.I bought a Technika from Tesco but this was faulty as it kept switching itself off.They sent me a replacement and this was exactly the same so hence why I bought the Wharfedale.With the Technika though I didn't have the resizing problem.Getting a refund on the Wharfdale as I have to resize every channel even when I've just paused the live TV.Seriously starting to lose the will to live - if there's a faulty item on the shelf it seems to have my name on it !
    Problem Solver:
  • 6 Answers
GO ONTO YOUR SKY SETTINGS AND ADJUST FOR 16,9 THAT SHOULD CURE YOUR PROBLEM
Posted on Feb 15, 2008
I need an online manual for my Wharfedale 37" tv model number is L37TA6A
Hi Martyn. You can find your manual here:
http://www.manualowl.com/p/Haier/L37TA6A/Manual/102907
That TV should have both VGA and HDMI slots for you to connect your PC/Laptop to it. Just hook it up then press the window key+P and select your view mode.
Mar 11, 2014 | Televison & Video
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Just recently my sharp aquos lc 40 e is stuck in stretch of wide screen and the heads or top of things are being cut off. When i go to view mode it only gives me 4 options wide, stretch dot to dot or zoom...
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
Aug 29, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I've notice while watching Baseball and Football games that it cuts of the the box scores on the top left hand corner and also on the bottom of the screen I'm not able to see all the content...
This problem u must play with the tv orignal remote.Look on the tv original remote for a buttons like Aspect Ratio,Picture Sizes,VIEW MODES,ZOOM.Just pushes one of these buttons until u have the desire screen format for u.The screen will jump every sizes,u can't get evrythings u want,have to give and take as the tv pictures exspan or contract.
Aug 12, 2011 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
Hi i" ve bought on
This may help. If it's not the exact model you have it will at least get you started as subwoofers are pretty much teh same for connection and operation.
http://www.wharfedale.co.uk/Portals/0/PDF_Data/Manual/DIAMOND9_range.pdf
Others here...
http://www.wharfedale.co.uk/Support/Download/Manuals/tabid/71/Default.aspx
May 06, 2011 | Wharfedale SW150 Subwoofer
The tv is only showing the picture in a small box on the screen. The re.st of the tv is blue. How do I fix this?
you will have a button on your remote control that allows you to select what picture size you would like in your case it sounds like you have it set to 4:3 and it should be set to 16:4 if this fails check your menu options as one of your factory default settings may have been changed by mistake
Jan 31, 2010 | Olevia LT37HVS 37 in. LCD HDTV
My tv picture is to large for the screen how do i reformat the size
a lot of the newer tv's will have a zoom button on the remote which will change the size of the picture to settings like normal, wide cinema...
Jul 19, 2009 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Picture in high def does not fill screen
That is normal. Most HDTV's have a format or picture size option on the remote or menu. It will give you options like full, stretch ot zoom to fill in the blank spots. The problem is those settings can also distort the picture size so people look funny.
Feb 28, 2009 | Protron PLTV-37 37 in. LCD Television
Picture size
They may have gotten to the zoom function. There is a zoom button on the cncealed part of my remote. Hit the zoom button to cycle through all the screen sizes.
Oct 26, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
356 people viewed this question
Top Televison & Video Experts
Electro Med Services...
