Question about Maytag Neptune FAV6800AW Top Load Washer
Od code Washer came up with a od code, tried unplugging, tried service mode locks work, error code won't clear? tom
  • Anonymous Feb 23, 2008
    Maytag Neptune fav6800aww top loading washer has od code since soap applicator on lid was removed and washed
  • 96 Answers
Od code is supposed to mean that lid has not been opened for the last 3 completed cycles. Also, apparently you tried the service mode and found the door lock to be working. So, unless the problem is with the electronic board itself the only other thing that could be happening is a faulty sensing switch at the door lid or a bad connection to it. I would try shorting the leads from the switch and see if the problem goes away. Then you might just need a new switch.
Posted on Feb 22, 2008
EE error code on reliOn blood pressure monitor?
Corrupt memory causes this.
Just guessing on your make and model type!
1 - Unplug the washer from power for 10 minutes to attempt to CLEAR THE CORRUPTED MEMORY on the main control board.
NOTE: You can try unplugging the washer multiple times to attempt to clear the corrupt memory. Unplugging the LG washer with the EE error code may clear the error code and no other action is required. The washer memory will be cleared or reset and the EE error code is considered fixed or repaired.
2 - If the code does not clear on the washer after unplugging it multiple times, this means the main electronic control board is faulty and needs to be removed and replaced.
3 - To be sure the main control board is the problem, run a TEST MODE if you want to continue the troubleshooting process or just replace the main control board and that will fix the EE error issue.
NOTE: How to run a TEST MODE on an LG front load washer is explained below...
4 - If you have unplugged the washer for 10 minutes and have done this multiple times and the EE code DID NOT CLEAR, you can run the TEST MODE and the EE error may come up with the FIRST PRESS OF START/PAUSE BUTTON DISPLAYS EE ERROR CODE. If this is the case,then you have a bad or faulty Main Electronic Control Board and you need to replace it.
Dec 16, 2017 | Washing Machines
Wtw 4950 wont start
you need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes
How to Read Vertical Modular Washer VMW Error Code Display
Calibrate/reset error
How to Calibrate Top Load Washer
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
Nov 22, 2017 | Whirlpool WTW4950XW Washer
Maytage Neptune TL gives od error code. Tried unplugging the machine. Tried many things, but nothing is working.
Could be loss of signaling thru the left hand Lid lock;
Google "Sticky Neptune TL Washer FAV6800AWW" for the Service Manual and support for troubleshooting the OD error code.
Mar 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
Jul 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Od code when trying to star
You have lost signaling from the Left Hand Lock. The washer has not see the lid go open thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
See if this post will help you Left Hand Lid Lock Troubleshooting
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference.
Rich
Jun 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
This washer definitely does what it wants to - od will appear when I try to start it - all I get is a loud beep and the washer will not start - but sometimes when I try to start it, the washer begins as it...
Hello inezfragala,
If you are only throwing the OD error code to the Console and you can’t clear it I feel you have a broken lead on the magnetic reed relay switch or severe pin/plug corrosion in the left hand lid lock. See the pic’s be low. Next Question do you want to DIY or call in a service repair company.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
If you want to DIY the fix I would start by removing the Left Hand Lid Lock. Follow the Service Manual page 34 Lid Lock/Reed Switch Removal.
The technicians thumb is on the Left Hand Lid Lock assembly. The Left Hand Lid Lock assembly is not a sealed very well and is subject to corrosion issues with its location near the bleach dispenser. If you are a DIY’er you won’t have any problem getting to the Left Hand Lid Lock assembly.
Unplug the 120VAC to your machine and follow the manual to raise the washer top from the base. The mating plug can be very difficult to remove from the assembly. Remove the 5/16 sheet metal screw holding the lid lock to the washer top. Once loose you can press the tabs and pull the mating plug from the socket pins in the Lid Lock. Be careful when you open the case halves of the Left Hand Lid lock assembly it’s very easy to damage those retaining tabs. Work very slowly with a small flat blade jewelers screwdriver or similar. If you have heavy corrosion issues you can clean up with WD-40 and some finger nail emery file board on the pins in the Left Hand Lid Lock.
If you need to replace the left lid lock here is the part number 25001048 or here another link.
Check to see if the Black and Red wires are on the magnetic reed relay switch solder connections have not broken loose from corrosion. They can be re-soldered back on if they have broken loose. If you have heavy corrosion in the Left Hand Lid Lock assembly and can’t clean up to clear the error code I would replace the Left Lid Lock. There is a possibility that the signaling is lost from the Left lid Lock plug back threw the machines wiring harness. This would require advanced troubleshooting using a DVM to trace +12VDC from the Control Board Back to the Control Board thru the L.H. Lid Lock. Don’t go near the Control Board with a DVM set to measure resistance/continuity you could destroy your Control Board.
Big time corrision issues with L.H. Lid Lock.
Re-solder lead to fix OD error code.
Broken wire on magnetic reed relay will cause OD alarm and you won't be able to clear.
This how the L.H. Lid Lock should look.
DIY pin out info.
Post back if you have question and I will try to help....Rich
Nov 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have a maytag neptune tl that comes up with an error code "od" Has anyone any idea what this is and how to fix it? Thanx Bruce
Open Door Error. - Problem with the door latch mechanism or sensor. For the od error, open the door and jiggle the locks.
It's possible that soap has gotten there and is making them not knock whatever it is they need to knock to register that the door has opened.
You might need something fairly long and thin such as jeweler's screw drivers
OD :The door has not been opened after two complete wash cycles. Door switch was not seen open since the last two final spins.
Here is a shop manual for your model.
Try to run the diagnostic mode, see manual. Or unplug for 5 minutes. Remember if this code reappears you may have a stuck or bad door latch.
if after running a diagnostic, and th latch is still reporting an error - it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
536 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
