Question about Zebra LP 2844 Thermal Printer
Solid red light after flashing firmware
Hi there.
I'm in trouble. My Zebra TLP 2844 doesn't want to take firmware. I was following instructions how to do it using DOS mode. After copying the file and waiting forever for green; my light stayed solid red. I've tried to send firmware few more times with the very same effect. Light is flashing yellow/red for a few minutes and than stays solid red. HELP!!!!!!!!!!
I'm about to eat my keyboard after spending three days with "her" on my side.
  • headupx May 07, 2008
    Hi jigeo :)
    I've double checked media and it's fine. Also swiched power OFF and ON several times. I remember every single word from Zebra webside. Nothing worked so far. Probably I have to get rid of the firmware being corrupted, i mean wipe it out. I have no idea how...
  • 3 Answers
Hi, I'm facing the same problem. could someone help please
Posted on Nov 01, 2012
  • 57 Answers
These are the 3 things listed as being wrong for the status light being solid red:
1. Media is out. Reload a new supply. Press feed button to
continue.
2. Power-up failure. Switch power OFF then back ON.
3. Printer ready to receive flash programming during
firmware download.
There's a programming manual available for download on Zebra's website: https://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
It might help.
Posted on Apr 24, 2008
  • Jill George
    Jill George May 08, 2008
    One more possible cause I forgot: that the printhead is open, not latched down all the way. Press down on the top
    cover of the printer to see if the error light clears and goes to green.
    How is the printer connected to the PC? Parallel cable? If it's with a USB cable or a networked printer, the DOS method will not work.
    There's a firmware downloader program that's an alternative to the DOS method. Go here to download this.
    -Download the utility and
    open program.
    -Select the correct communication method, serial or parallel.
    -Select Download and browse to the firmware.
    -Select Open and the file will be
    sent to the printer.
Everytime I turn my Zebra TLP 2844-Z printer on,
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, click paper output and enter the size.
Oct 01, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Unable to upgrade Zebra TLP 2844-Z printers firmware
What is the problem if this works?
May be there is a problem on the boot rom!
Jun 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
Jun 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
These 2 links will help you troubleshoot the problem:
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
TLP-2844-Z only prints using EPL2 not ZPL2
Download firmware, get latest firmware & Firmware download utility software directly from the Zebra website
Jan 12, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2844-z Flashing Red Light When I Try To Print
When the light flashes red, press the green button once. What happens then?
Oct 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra tlp 2844 trouble
Verify that the ribbon fits into position, back and forth. You can also calibrate the label by pressing the button while powering up the printer and release the button.
Aug 02, 2008 | Zebra R2844-Z Label Printer
Zebra TLP 2844 Error Condition
Qusetion, Using USB my TLP2844 detects as a LP2844ps. Weird, huh? Also when I calibrate it the label does not stop at the perferation. When I print half goes on one label and the other half goes on the next label. Someone told me once there was a trick to get it to calibrate correctly. Anyone here know this? When I print a test page, it feed the correct amount of label.
Dec 04, 2007 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
1,558 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
