D-Link DSL-G624M not providing valid IP addresses. all appears to be working fine but the PC can not get a connection that works. rebooted and reset many times but no joy
First thing to do is check your Modem from your Internet Provider, without using your router, to know if you have a fair connection. Connect your computer directly to your modem. If your internet is okay
Second, connect your computer to your D-Link router using a Lan cable wire (utp cable), (don't connect your router to your modem ) then check your computer if it has an ip address from your router. If it has an ip address that means the wireless function of your router is not working.
Note:
( During this steps always obtain the ip address of your computer automatically, because your router will provide the ip address in your computer )
Make sure that your router is acting like a DHCP server.
also make sure that your pc's ip is set to "obtain automatically" under local area connection->properties->internet protocol->properties
Testimonial: "appreciate the quick response. many thanks"
thanks for that but the DHCP server setting is on and all PCs set to obtain address automatically - any other ideas ?
i have 100mbps connection through the LAN so it is definitely the wireless functioning of the router
