Question about Harman Kardon AVR 635 Receiver
Center Speaker sound just not right
I just purchased an HK AVR 645. The voice coming from my center speaker just doesn't sound crisp when watching TV shows, especially Lost. I am using a monster optical cable going from my cable box to my receiver. have tried tweaking every area I can think of to try and fix this problem. Does anyone have any suggestions on what i can do for this problem? The speakers are high end Focal's that i just recently purchased so I do not think it is the speaker. Any help would be great. Thanks
  • 70 Answers
If the optical cable was bad, the sound would be distorted period. The optical cable (whether coax or fiber) just simply carries the coded audio to the receiver which in turn decodes it. I have never heard of a signal just screwing up the center channel, and I've been at this better than 30 years. Not to say it's impossible, but very unlikely.
Did you try swapping speakers? Move the left one to the center and the center to the left. Does the center remain "distorted"? Does the left become "distorted"? If the center remains distorted, the receiver's center channel has something wrong with it. If the left is distorted, the speaker has a problem.
For the future. it is un-neceaasy to purchase expensive cables. In fact it could make things worse. The claim to fame of most expensive cable manufacturers is the gold plating on the connectors. Unless the bioth sides have gold plating (receiver, cable box) this actually creates a capacitive reactance between the different metal types. FYI-capacitive and inductive capacitances are the basis for designeing cross-overs, filters, etc. So basically, an undesired filtering effect is created. This applies to speaker cables, audio, video, etc....
Posted on Feb 17, 2008
Hi. We have a Harman Kardon DVD and AVR and a Proline TV. When playing DVDs the sound from the AVR is not playing all tracks (usually the voice track is missing) - just background music and the odd door...
Your HK DVD probably has outputs for left and right audio and video (possibly color coded red, white, and yellow). These should connect to the corresponding DVD (or VCR) inputs on the rear of your AVR. When you play a DVD with your AVR set for DVD/VCR input, you should hear all of the stereo audio (there are no "missing tracks"). Next, review your speaker connections. They should be connected + terminal to the corresponding + terminal on the AVR, etc. One or more speakers may be connected backwards. If your AVR has speaker system A B provisions, be sure that speaker (system) A only has been selected.
Dec 23, 2013 | Harman Kardon AVR 225 Receiver
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
Voices vs. sounds
If you are passing video thru the monitor out to the TV, this will go much easier. First Press the GUI Menu button on the remote. If connected to TV, on screen menu will appear. Go to Manual Setup then (right arrow on the 4 way with the ok in middle) Speaker Settings then Speaker Select then go to Center Channel arrow right again and make sure it's "On" If it is, then go back to the main speaker settings and toggle to Speaker Level. Then select center channel and arrow right turns volume up. If you still have no audio, post a comment and I can help you troubleshoot further. Hope this helps
Nov 19, 2009 | Yamaha RX-V496 Receiver
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Static and popping from Harmon Kardon AVR 340
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Jan 28, 2009 | Harman Kardon AVR 25 MKII
HK AVR 120 (left speaker not working)
Hi, your analysis are right, your speakers has no problem, the problem is in your receiver.
there are several factors that affects it, try some troubleshooting: and answer this questions:
1. During this event, what is the source of your INPUT audio signal?
Have you tried to replaced your RCA cables that connected to the source of your receiver?
If YES, then problem really exist in the internal system of your receiver. may be you have overdrive your receiver unintentionally, which cause the Power Amplifier to malfunction,
On this event, I would suggest that you bring your receiver to it's Service Center for repair,
This problem needs technical troubleshooting of a qualified technician.
Dec 25, 2008 | Harman Kardon AVR 120 Receiver
AVR 120 5.1 -dolby surround sound & logic 7.
The problem is fixed...
and every thing sounds great !!
Thanks for the premium assistance to help solve my problem...
Dec 07, 2008 | Harman Kardon AVR 120 Receiver
Denon AVR-3300 Center Chanel Sound Problem
My guess is You have dried out electrolytic capacitors causing failure. These receivers when they get over 6 years old start drying out fluid in capacitors especially on regulator p.c.b. causing noisy supply lines. I work for Authorized service center in Michigan If you need repair and Shipping to Michigan is economical let me know
Feb 06, 2008 | Denon AVR-3300 Receiver
Harman Kardon AVR 635 Receiver Logo
166 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
