Question about Canon imageRUNNER C3200 Copier
Paper Jams My Canon C 3200 is getting paper jams or the paper just won't go through the heated rollers. It's as if the roller isn't rolling
  • 86 Answers
How many copies has the copier done ?
When was the last fuser fitted ?(heated rollers)
the fuser rollers have a life of about 100,000 copies
and you change the whole unit at 200,000 copies
Posted on Feb 16, 2008
There's no foreign objects in my printer and I also put the paper in properly... I have ink, etc... My paper gets jammed immediately on the right side when trying to print. Help!
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Jul 23, 2011 | Office Equipment & Supplies
Hi my canon mx 310 is jamming all the papers sent through it goes in ok and once it hits the wheel that turns the paper it is pushing it to the right and ripping the paper
check for paper residue at the right roller...then...
.The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Jul 07, 2011 | Canon PIXMA MX310 All-In-One Printer
The paper jams when I try to print. It will not feed from either the lower or the upper paper feed. It is jamming in the back of the printer.
Paper jams
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Open the Rear Cover.
If you can see the jammed paper, slowly pull the paper out.
Clean the rollers in the rear section too.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | Canon PIXMA MX850 Multifunction Printer
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
My canon printer is getting jammed, when it tries to run thru it goes on an angle to the left side and gets jammed, How do I fix this?
That means that there is something jamming the paper on the right side. Check to see isf there is some paper residue from a previous jam near the rollers.
Also do the following:
Thanks, Joe
Apr 27, 2011 | Canon PIXMA® mini260 InkJet Photo Printer
Paper will not feed through to print
Paper jams
Thanks, Joe
Feb 18, 2011 | Canon Office Equipment & Supplies
Asked me a paper was jam
You didnt wrote where it is the paper jam.
Here are few common jams:
  1. if the paper jams in fuser unit, do/check next:clean the paper delivery rollers ( when you open left door its two roller on axis beneath the drum ), check the sensor flapper beneath the drum unit if its worn out you need to replace it, does the paper comes out like bent in the roll? open fresh pack of the paper and try again it could be moisture fault.
  2. the paper stucks in pickup section, clean the paper pickup, feed and separation roller, to do that remove paper drawer and you will be able to see the rollers on left inner side.Open the lower leftside door and check the paper senzor in the middle.You can apply some wd40 on spring of flapper or on left side bushing.
  3. dadf jam, check for any paper leftovers and clean the paper pickup and feed rollers
Hope that helps!
Sep 07, 2010 | Canon iR 2016i Black and White Copier
Paper Jams - Multiple Pages Pulled - New Rollers Installed
If you have de-stapled papers, the papers may still be held together where it was stapled. Fan the papers before feeding, Check if the '******' roller (the light brown bottom roller) is clean.
S. Mohan
Feb 16, 2010 | Canon DR-7580
Paper is jamming during printing process. Gets half way round and jams. please suggest solutions
There are rollers that the paper has to go between to be pulled forwards. When the rollers get dirty with paper dust, paper starts jamming. So you need to clean the rollers with a moist (not wet) soft cloth, Keep rolling the rollers manually and keep cleaning them. Then allow a few minutes to dry them up. And no jam after that.
Dec 10, 2009 | Dell 1100 Laser Printer
Paper jams
Check solinoid transformers that controls opening and closing of paper handling trays. Check and clean sensors from in and out of paper path. Check and clean paper rollers or heat rollers for dust and paper remains pieces. Please determine when is the paper jams occurs. Hope this gives you hints.
Best regards,
Rosener
Feb 05, 2008 | Lexmark E238 Laser Printer
Canon imageRUNNER C3200 Copier Logo
245 people viewed this question
old marine
old marine
