Question about Lexmark X1270 All-In-One InkJet Printer
Scanner and Copier won't work.
I have re installed my 3 in 1 Lexmark three or four times already and I still can not get my scanner and copier to work.
  • 3 more comments
  • Anonymous Feb 16, 2008
    My all in 1 printer and copier will not work i need to know whats wrong and why it won't make copies are print it will not scan what doo i do?
  • Anonymous Mar 28, 2008
    I bought my printer lightly used and with the instal disk but after I installed it I can not get it to scan
  • Anonymous Apr 02, 2008
    i keep pressing the scan button and nothing
  • Anonymous Apr 20, 2008
    Scanner will not work
  • Nyestar40 Apr 21, 2008
    i lost my cd and cant get it work withiout cd, what to do, but before that my printer stopped working when there was ink
  • 4 Answers
I got the scanner to work from Microsoft photo gallery after weeks of trying to get the lexmark program to work.
Posted on Feb 21, 2008
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
Tip
FREE Printer Drivers for Lost Driver Installation Discs
Download Drivers,...
Download Drivers, Software and Manuals for free from the manufacturer website.
Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet
HP Multifunction Printer/ Copier/ Scanner InkJet
Canon Multifunction Printer/ Copier/ Scanner InkJet
Brother Multifunction Printer/ Copier/ Scanner InkJet
Lexmark Multifunction Printer/ Copier/ Scanner InkJet
Remove and Install the Printer Driver for your product:
DRIVER REMOVAL
1. Turn off the printer and disconnect the USB cable.
2. Click the Start button and select Programs or All Programs.
3. Locate and select Printer Software Uninstall.
4. Restart your computer !
INSTALLATION
1. Go to the support website.
2. Select your model and download the printer driver for your Windows operating system.
3. Double-click the downloaded file and follow the on-screen instructions.
4. When prompted, connect the USB cable and turn on the printer. Installation should complete automatically.
Do not reconnect the USB cable until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer.
on Jan 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Lexmark X5340 - All in One Printer/Scanner/Copier/Fax
Please follow the steps given below to add the scanner using Scanner and Camera wizard.
1. Plug your scanner into your computer.
2. If your scanner is "Plug and Play," the "Scanner and Camera Wizard" starts or double-click add device. Follow the instructions on your screen.
Note:
1. To open "Scanners and Cameras," click "Start," click "Control Panel," click "Printers and Other Hardware" and then click "Scanners and Cameras."
2. If you have a "Plug and Play" scanner, Windows detects it and installs it automatically.
3. If your scanner is not "Plug and Play," follow the installation instructions that came with the device.
4. If your scanner is not listed in the "Scanner and Camera Installation Wizard," try to install it using device manager.
5. After you install your scanner, you can test it.
Oct 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
I just bought a new lexmark copier, scanner, fax,
This should give you a good explanation of what ocr is.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1268319518_0_en,00.html
Jul 07, 2009 | Lexmark X3550 All-In-One Printer
Try to print--scanner failure appears
I think your printer has been, for some time now, trying to tell you something and the scanner failure message
is the last in a series of messages.
First, the copier and the printer and the scanner worked fine, "for years",
Then, the copier stopped accepting scans, while printing from data sent by your computer.
Then, you received a scanner failure message again, and will not accept data from your computer, and
"won't print at all"
Your printer/scanner/copier/fax has needed service for some time after years of continuous service.
Evaluate now, based on its initial cost and the lesser cost of All In Ones whether you have already
obtained sufficient service to amortize the cost over time, and you may conclude that service is eitherr
cost effective or ineffective at this time.
Apr 17, 2009 | HP Office Equipment & Supplies
Copying on my Lexmark 6500 four function fax, copier, scanner, pr
turn your copier and all attachments off wait ten minutes reboot should b ok
Jan 19, 2009 | Office Equipment & Supplies
I have a Dell XPS420 & I have a Lexmark4200 it is an all in one
The key will be the drivers. If you have an install disk for the fax, copier, scanner and it loads without problem then it should work.
Dec 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
