Question about Dimplex DS5603 Heater
Bulb burnt out
How do I change the bulb in the unit? Where do I go to open unit to get to the bulb?
    Problem Solver:
  • 14 Answers
Deivers tail light/brake light do not work..reverse works..when i lock my car the lights flash except for that one and the drivers light..headlights work fine though.drivers headlight bulb connector looks...
Could be a broken wire at the socket. Sounds like a burnt bulb also. Sometimes a burnt bulb will do the same thing as you are describing. Once you get this fixed, all should work. If flashing to quickly, replace the flasher stat unit!
Sep 04, 2013 | Volkswagen GTI Cars & Trucks
How do i change the break light bulb
TO CHANGE BRAKE LIGHT BULB YOU WILL HAVE TO OPEN THE TRUNK, PULL BACK THE CARPET WHERE THE REAR TAILLIGHTS ARE AND UNSCREW THE SCREWS THAT HOLD IN THE LIGHT, ONLY THEN CAN YOU CHANGE THE BULB THAT IS BURNT
Jan 28, 2011 | 2000 Ford Focus
How do you change burnt put back up lites in 2003
Open trunk, remove back liner, push bulb in and turn left, then let go and it should pop out.
Mar 23, 2010 | 2003 Chevrolet Impala
I can't figure out how to open my dome light to change the bulb
some cars now days have closed units that you have to completly replace like jeeps, it looks like a bulb inside a glass unit, but it really is the entire bulb.
Mar 04, 2010 | 2003 Toyota 4Runner
How to change burnt out bulb on overhead console
popthe clear plastic cover off and pull the bulb out.
Nov 12, 2009 | 2008 Ford F 250 Super Duty 4WD
System error cycle power. i already reinstall the bottle and the imaging unit. still same error. the unit is brand new
Change the temperature sensor from the fuser unit. There is no need to chang the fuser unit, it is expensive. I repair the sensor, it is a mechanical device who remains blocked.
Nov 06, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
How do i change my rear indicator bulb in my 04 beetle?
open rear hatch and look strait down on inside boot well. the plastic trim has access holes that pop out on either side just behind the lights. pop out the access cover on the side with burnt bulb, then reach inside that hole and you will fins a large plastic "wingnut", unscrew it<careful not to drop it or you'll have to take the whole boot apart to retrieve it> after removing wingnut carefully pop out lens from outside , replace bulb and reinstall after testing
Mar 19, 2009 | 2000 Volkswagen Beetle
Neither lights nor fans work
don't know model but they are all much the same.
there will be a pcb behind the control buttons and you will find some of the track burnt out causedd by the bulb blowing. do a soldered wire link across the burnt section of the track
Sep 25, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Dimplex DS5603 Heater Logo
569 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
