Question about Microwave Ovens
Neff HTHB86K Microwave oven.
Neff combination microwave not operating in microwave mode ,LCD display reads E9. Both oven and grill facilities working correctly. Occasionally microwave will operate for set time period, no heat in food. Next attempt unit will stop halfway through time and error E9 and display : MW fault acknowledge with stop.
Would be great if someone could identify fault as I am fed up eating salads.
  • Anonymous Mar 20, 2014
    The microwave started to not heat properly or at all and it would stop before the time set to heat the food. It just started doing this a few days ago then the error H98 showed up on the LCD screen on the front of the microwave instead of the where the time goes.
  • Anonymous Mar 28, 2014
    currently i have oven of brand singer the model is SMW928 i dont know how to operate it and set the time for oven
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Posted on Feb 15, 2008
WHEN I SUBMITTED MY PLEA FOR HELP TO GET A MICROWAVE USER/OPERATOR MANUAL, I WAS ASKED: WHAT MAKE IS IT?
that model is from the uk,you need to search over there for it,i just searched for an hour and come up with this, Accumetrics Inc Announces United Kingdom Distribution Agreement With...
22l is how much it holds,not the model number,Elitech commercial grade steam oven/combi grill - in VGC - not used a great deal, but a very handy addition to any kitchen at busy times!
Voltage - 220-240 V input 1650 watt when on steam mode, 1250 oven/grill mode.
Dimensions 220x315x312 mm
Manual available online to download - (Ref Elitech EA053747)
Capacity 22L Instruction Manual Copy ELITECH Steam Oven Combination Grill Model Ref...
May 11, 2015 | Microwave Ovens
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
Ceramic coating problems in microwave
1. you did put metal plate in it or spoon in it once.
2. oily spot left without cleaning.
3. you can paint the scratched are after cleaning it. not recommended
Mar 24, 2014 | Neff Microwave Ovens
We have a neff hthb86k oven works all displays work when we use the microwave and press start runs for 2-5 seconds then stops any sugegstions ? thanks
I also have the same problem, the oven is just over 3 years ole with minimal use, sounds like a common problem, has anyone found an answer yet/
Jun 10, 2010 | Microwave Ovens
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Neff h7871
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Neff H7871 Convection/Microwave Oven
I have a Neff Microwave/Oven/Grill combo. The grill and the oven parts still work, but the clock has gone off and the microwave part does not work. What can i do to fix this?? Thanks
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jun 25, 2008 | Neff Microwave Ovens
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Microwave Ovens Logo
978 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
