Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor 3200 External Drive
My puppy chewed on the ac adaptor cord. What specs am I to look for when replacing?
  • mfp00018 Mar 11, 2008
    Please disregard my suggestion that the after market replacement power cord from Digikey.com. This replacement arrived but the female plug is not the correct specs. This will be shipped back and my search continues.
"Universal Adapter".........What this solution fails to point out is that universal adapters are not so universal! To properly power up this external drive (more then likely goes for any piece of equipment) you'll need to sync up the voltage input, output, amps (critical) and in this case the size of the cord plug (2.1mm I.D. x 5.5mm O.D. x 12mm Female) according to the mftg specs.
I found the following web site to provide me with an after market replacement at the best price.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=T998-P5P-ND
Posted on Mar 06, 2008
    Problem Solver:
  • 9 Answers
You can buy a universal adapter. It works 99% of the time on all harddisk housings.
Posted on Feb 15, 2008
I applied the wrong ac adaptor to my external hardrive
My laptop adapter delivers 4A (ampères). Examine the HD adapter, and read all markings, looking for output intensity ( a number followed by a capital A). Do the same with you computer's adapter.
If output intensity delivered by the computer adapter is higher than the output intensity of the HD adapter, chances are you have blown out a fuse inside the HD enclosure (if you have a fuse)
In addition to voltage, intensity, there is the question of polarity of the adapter (positive inside ---C+ or positive outside ---+C. You can verify compatibilties of the adapters by comparing the C with a dot on both adapters.
Hope it helps sort things out a bit.
Sep 04, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 problem!!!
First, try another USB Cable. If that does not work properly then I would suspect the box or the drive has failed. If you just bought it, return it to the store and complain. They may replace it. As for your data?
Now if you want to become techie you can remove the hard drive from the box and attach it to you computer either copy the files back if you do not have them on your computer or format the drive if you have your files. Then put the drive back in the box and try to get a refund or buy a different external. I like a metal box with an AC cord plug. Best of luck.
Jun 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I have tried to order replacement power cord 12 volts 2 amps for maxtor 3200.I haven't been able to find one.
This is a common problem, most of the AC cords for these devices cannot be purchased seperately.
You have 2 basic options:
1. Purchased a used model of the same model # off eBay or a similar Auction site and use it's AC cord
2. Take the drive as is into your local computer store and purchase a new External drive caddy which will include it's own AC adapter(usually $30-$50) and ask their technicians to move you maxtor drive into the new caddy. There is one thing they will need to no, what type of HDD it is, SATA or IDE but if you do not know they will be able to tell as soon as they open the maxtor shell.
Either way you should be able to access all of your files, just a question of seeing which way will be cheaper and easier for you. I generally recommend the second method as the new shell will come with it's own warranty should something fail which used parts generally do not.
Hope this helps FixYa,
Chris
Apr 30, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Lost my AC / DC power adapter for Maxtor 3200 Personal Storage , where can I find one to buy?
The following site guarantees compatible replacement.
http://www.lcdpayless.com/productpage.php?productId=2511
I've been searching for a replacement as well. I found the specs on the original cord at the following site.
http://www.libertye-online.com/servlet/the-1642/new-APD-I.T.E.-POWER/Detail
12V, 2A, positive inner post, 2.5 inner diameter (ID) and 5.5 outer diameter (OD).
I don't think I would buy the exact replacement ADP brand fom the site above. Many have complained about it failing at the 2-yr point. I am considering the following replacement from the same website.
http://www.libertye-online.com/servlet/the-1218/new-Challenger-I.T.E.-POWER/Detail
NOTE: the input AC voltage range is different on this one, but it should still work in the USA.
There are other options on ebay.
http://electronics.shop.ebay.com/AC-DC-12-Volt-/88758/i.html?_npmv=3
Let us know if anyone has specific success with any of these or others.
Conan135
Jan 24, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor 3200
what was the voltage difference between the supplied adaptor and the one you plugged in by mistake ?
Robert
Dec 17, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Power cord for maxtor 3200 external drive
Nov 16, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
268 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
