Question about Sony Cyber-Shot DSC-F505 Digital Camera
DSC-F505 does not show as a disk drive
Hi all,
I recently upgraded this computer from 2000 to XP. Computer is a Dell GX270, P4, 3.2 GHz, 3.0 GB of RAM. Camera used to be recognised previously on Win 2000. Device Manager recognises it as a Disk Drive- Sony DSC-F505 USB Device. But it still does not show up as a disk drive with a drive letter assigned to it. What can I do?
  • 1,472 Answers
Dmangadu
It sounds like the drive letter that the camera wants is already assigned to another device. The link below will help you change the drive letter.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Apr 20, 2010
How to get more disk space on an old dell computer XP
Support for XP has ended, the operating system is 14 years old, It's time for an upgrade.
There is probably a lot of things wrong with the laptop and not worth messing around with.
I would suggest backing up any files you wish to keep and get yourself a newer laptop!!
Mar 26, 2015 | Dell Inspiron 5100 Laptop Notebook...
Gx270 dell During istall of OEM XP I get blue screen codes 24,8,&
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 41f927c.jpgd3990ed.jpgALL these systems suffered from defective capacitors caused by bad manufacturing at the component factory. I have put here a pic or two for you to see what defective caps look like. Call Dell and ask them. I some case a while back they were doing a free motherboard replacement. The problem causes a whole raft of errors to occur from blue screens to "thermal event error" and the only thing that fixes it is to have the motherboard replaced. Hope this helps you
Kind regards from London
Mark
Aug 25, 2009 | Dell Optiplex GX270 Intel Refurbished...
I have a Dell Optiplex GX270 running on windows XP pro. It has 2MB RAM and 80GB hard disc drive. When I checked to see if I could run Windows Vista Ultimate, the checker said I could, but might need to...
You'll need to have at least the following specs to run vista comfortable; 1 or 2 Ghz processor 1 or 2 GB RAM Video : AGP with 256mb or more cache Yoy might also have to consider changing your power supply.
Aug 13, 2009 | Dell Optiplex GX270
Video card upgrade
Yes you can put that new videocard. Your computer requirements meets videocard needs
Aug 05, 2009 | Dell OptiPlex GX270 PC Desktop
2nd HDD
Check Computer Management / Disk Management. Windows on Windows XP, Probably the Drive needs formatting first and partitioning before it will visible on My Computer. By Default the new Hard Drive is "Unpartitioned / Unallocated". So acess disk Management to format and partition the Hard Drive.
To access the computer management and disk management and create and partition under disk management, Check Videos for guide :
Nov 10, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
My hard drive shows only 1.5 GB instead of 100
is it correct that you installed XP from an "upgrade" pack?
when you installed XP did you convert the file system to NTFS?
Dec 26, 2007 | Maxtor Hard Drive
NetFlix movies
If your computer has these hardware specs:
Windows XP with Service Pack 2 or higher, or Windows Vista; Internet Explorer version 6 or higher; Windows Media Player version 11 or higher; an active broadband connection to the Internet; 1.0 GHz processor; 512 MB RAM; 3 GB free hard disk drive space.
you should be ok with the movies download and watch.
Other wise you will probablt need new hardware which is really tough to upgrade on a laptop.
Dec 12, 2007 | Dell INSPIRON 6000 CENTRINO...
Sony Cyber-Shot DSC-F505 Digital Camera Logo
66 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
